Racing Oils contain additional additives for increased horsepower and reduced friction on metal parts, provide extra wear protection for high compression/higher horsepower engines, and include less detergents than regular conventional motor oils.What solutions does Valvoline offer to the zinc issue?Valvoline offers two solutions to the zinc issue:Valvoline VR1: Contains 75% higher zinc than SM motor oil with a balanced additive package designed to work in both racing and street-legal applications. This product will protect older style push-rod and flat tappet engines. Valvoline provides this product in both multi and mono viscosity grades: 20w50, straight 50, 10w30, straight 30, straight 40, and straight 60.Longer-Lasting Zinc/Phosphorus: Valvoline uses an advanced zinc/phosphorus additive that keeps higher levels of phosphorus in the motor oil where it protects the engine instead of poisoning the catalytic converter. Valvoline is the only brand offering this unique additive across its entire line of passenger car motor oils including SynPower -- the only synthetic offering this additive.
Interesting info on them. Their oil typically has twice the amount of zinc anc phosphorous than what I am using (not sure if that's important for my engines - the Stang has over 150k on the clock).... but interesting nonetheless.....
