Author Topic: &^*($)%#(*%&  (Read 1280 times)
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
Re: &^*($)%#(*%&
« Reply #25 on: April, 19, 2010, 05:59:50 PM »
LOL.
It was right after I switched to Mobil 1 Synthetic that I wiped the lobe in my 55k mile engine.  I wouldn't run that stuff in ANY flat tappet engine, if my life depended on it.
I run nothing but Royal Purple in the flat tappet engines now.
You really need to pull the pan and check a main cap/bearing and rod cap/bearing.  It's cheap insurance for the price of a gasket and a couple hours work.
I probably will. Not too fond of the whole scabbing the oil pan gasket idea.
Offline apollard
Re: &^*($)%#(*%&
« Reply #26 on: April, 19, 2010, 06:02:32 PM »
Hmmm... I've got well over 400k on 4 different engines, all flat tappet, several high lift, all with Mobil 1 15-50 or 5-30. One was broken in at the factory with Mobil 1 15-50, and has had it all it's life (182k now). No cam issues, no leaks, leakdown is less than 10% on the 182k engine.
Of course, I also sold a Pontiac with 320k on it, original engine & trans, and I towed a boat with that car. Havoline dino oil it's whole life.
So obviously YMMV stands here.
« Last Edit: April, 19, 2010, 06:04:24 PM by apollard »
Online B67FSTB
  • President, StangFix Belgium
Re: &^*($)%#(*%&
« Reply #27 on: April, 21, 2010, 01:06:04 PM »
Sluggo
I looked at the cam and lifter but am I mistaken?
Isn't the lifter damaged on the wrong side ? I mean , did they install the lifter the right way ?
The lifter is damaged at the pushrods side.Or are the marks from a floating pushrod?
Bruno
Offline Sluggo
    • www.StangFix.com
Re: &^*($)%#(*%&
« Reply #28 on: April, 21, 2010, 02:06:33 PM »
Sluggo
You are looking at the bottom of the lifter. It wore clean thru the bottom and into the inner return spring.
Offline Starfury
  • My car HATES me
Re: &^*($)%#(*%&
« Reply #29 on: April, 22, 2010, 04:59:39 PM »
Mobil 1 15W-50 is the only variant that has a high zinc content for flat tappet engines.  If I could get my motor to stop burning/leaking so much oil, I'd probably switch over.  Meanwhile, I've been running Valvoline VR-1 for 15k mi on the new cam with no problems.  The first cam lasted ~6k on Castrol GTX.
Tad H.
'67 fastback
331 stroker
3sp m/t
Offline johnpro
Re: &^*($)%#(*%&
« Reply #30 on: April, 22, 2010, 07:03:33 PM »
I'm talking Mobile 1 synthetic.  Do not run it in a flat tappet engine without an additive.
I will however agree, that YMMV.  It's just not worth the gamble to me, though.  Changing cams is not fun unless you were planning to change it.
Offline Sluggo
    • www.StangFix.com
Re: &^*($)%#(*%&
« Reply #31 on: April, 22, 2010, 07:22:01 PM »
Indeed.
Offline apollard
Re: &^*($)%#(*%&
« Reply #32 on: April, 23, 2010, 03:36:53 AM »
I'm running Mobil 1 synthetic 15W50 (not sure there is a non-synthetic). Flat tappets, no issues with hundreds of thousands of miles. One cam broken in with that oil.
Reportedly, M1 15W50 has 1200 ppm zinc - in the same rangle oils used to have.
Offline Sluggo
    • www.StangFix.com
Re: &^*($)%#(*%&
« Reply #33 on: April, 23, 2010, 05:20:09 AM »
Crappy cell pic of the nearly completed unscheduled camshaft swap. I'll get some real pics today.
Going for the factory look.
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
Re: &^*($)%#(*%&
« Reply #34 on: April, 23, 2010, 07:05:03 AM »
Sheeeuuuut.  Tell me about it.
Offline apollard
Re: &^*($)%#(*%&
« Reply #35 on: April, 23, 2010, 07:06:04 AM »
Looking sweet.
Offline 70_Fastback
Re: &^*($)%#(*%&
« Reply #36 on: April, 23, 2010, 07:08:30 AM »
Going with factory air cleaner too?
Offline Sluggo
    • www.StangFix.com
Re: &^*($)%#(*%&
« Reply #37 on: April, 23, 2010, 04:21:32 PM »
Yeah, but you've never seen one like it. It's a what if, sluggafied air cleaner. Only available on 427 Cobra Jet Windsor  :craz
