Linux Mint 11 Rulez....
Don't forget the engine ground strap that is present on many of these cars - it attaches to the firewall and the back of the passenger side cylinder head. It is very easy to overlook - ask me how I know!-Rory
The stand has been ordered and on its way from Broadway Lift and Equipment in San Pablo. I could have gone to pick it up myself but oh well, its about 40 miles from my house.Had to modify this post to say that I just recieved a phone call that the engine stand has arrived.
But Abe, I already gave you an engine stand. Where did it go?
Abe, I don't know what you're worrying about. Heck when we pull hard enough it will all come out...connected or not. :craz :vic
But we are stricked about no drinking and driving.
Abe,Like Pete said, it's easier just to get the load leveler installed and play it by ear once the engine starts lifting out of the car.What you can do to speed up the engine/trans removal process is:Driveshaft removed.The two nuts securing the transmission mount to the transmission crossmember removed.Speedo cable disconnected and tucked up along a frame rail.Ebrake cables disconnected at their front end and out of the way.Nuts on the two bolts securing the transmission crossmember to the floor support removed (leave the bolts installed until the hoist is connected).I noticed in your latest photo's that the cowl to shock tower braces are still installed. Are you going to remove the engine with those installed? If you'll be cleaning/detailing the engine compartment later, you might as well remove those braces now to open up the engine compartment even further for engine removal.Nuts removed from engine mount to frame bolts.
Nor Cal StangFix'ers rock!
