Author Topic: Adding a breather to a valve cover  (Read 388 times)
Offline Kooter
  • Quiet Type
« on: April, 09, 2010, 10:35:43 PM »
I just want to run this buy everyone to make sure I am not missing anything when it comes to adding a breather to a valve cover. It looks like you have to drill the appropriate size hole, install a rubber grommet, and insert breather. Am I missing anything or is it this simple?
"A man with cold hands and empty pockets is an idiot"
1966 A Code Convertible with a bench seat
Offline silverblueBP
    • My 66 2+2
Re: Adding a breather to a valve cover
« Reply #1 on: April, 10, 2010, 03:51:14 AM »
I added a baffle to keep oil from splashing directly up into the cap.
-Mark-
CarDomain
Offline AzPete
  • Classic...less
« Reply #2 on: April, 10, 2010, 05:40:23 AM »
Add a baffle for sure but not so low that it hits the valves.
USAF/Ret.
7 Previously owned..66-07
Offline blue65coupe
  • Banned
  • where's my short bus
« Reply #3 on: April, 13, 2010, 05:12:05 AM »
You're on track.  Do what they said with the baffle.
Duane
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« Reply #4 on: April, 13, 2010, 06:21:33 AM »
What valve covers do you have that don't have a breather provision?  Or are you relocating it to the rear on one side?
Offline Kooter
  • Quiet Type
« Reply #5 on: April, 13, 2010, 10:33:03 PM »
Thanks for the help guys. I will add a baffle as well.  What is the best way to secure the baffle without ruining the outside finish?
Jeremy,
They are trick flow valve covers. http://www.precisionraceengines.com/parts-and-accessories/sheet-medal/bbf-big-block-ford/bbf-ford-racing-aluminum-valve-covers-1.html The guy I bought the heads from gave them to me. One of the covers does not have a hole. I am hoping it will be a quick fix and not eat up to much time while I am home.
« Last Edit: April, 13, 2010, 10:34:58 PM by Kooter »
Offline Kooter
  • Quiet Type
« Reply #6 on: April, 14, 2010, 03:13:31 AM »
Does this type of baffle accept a push in  breather?
http://www.summitracing.com/parts/SUM-440332/SuggestedParts/?prefilter=1
Also is there a difference between the open and closed element breathers.
Offline daveSanborn
« Reply #7 on: April, 14, 2010, 05:20:27 AM »
Quote
If one of the valve covers does not have a hole.... then the other valve cover does?  I assume that the one with the hole in it is for adding oil and can't be used for a breather port also?
Quote
Yes.
Quote
Yes.  An open element breather vents to ambient air pressure and is IMO less effective.  A closed element breather vents.... usually through a Positive Crankcase Ventilation (PCV) Valve that is connected either to the base of the carb or to the underside of the air cleaner and is IMO more effective.
BTW, those are very nice valve covers.
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #8 on: April, 14, 2010, 06:13:23 AM »
What I'm doing with Shag is on passenger side, closed breather cap to pcv to carb.  Driver's side closed breather cap to air cleaner.
