Author Topic: Which battery should I get?  (Read 1037 times)
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« on: March, 29, 2010, 07:30:51 AM »
Does the 67/68 use a 24F series battery?   Any particular favorite brand?   I don't want a red battery in the engine bay.
Offline B67FSTB
  • President, StangFix Belgium
Re: Which battery should I get?
« Reply #1 on: March, 29, 2010, 07:40:34 AM »
IT SHOULD BE A GOOD ONE !!  :craz :craz :lol :lol :lol
I have a black battery , orig from mercedes.And pulled off all the stickers of course !!! 12v - 74Ah
Don't know about american standart  :sad :sad
B.
« Last Edit: March, 29, 2010, 08:06:32 AM by B67FSTB »
Bruno
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
« Reply #2 on: March, 29, 2010, 08:03:41 AM »
I prefer Optima batteries.
Although they are red or yellow (depending on your selection), you could always paint the top whatever color floats your boat.
Mike
Offline 66gt350
  • Ah like me sum gunz...
« Reply #3 on: March, 29, 2010, 08:05:55 AM »
+1 on Optima.  I've got a red top, and it's a great battery.
-rob "Ricky Bobby"
Offline apollard
« Reply #4 on: March, 29, 2010, 08:06:34 AM »
In the stock location, you'll need the 24F. Lots of options out there, but nearly all are green, red, or yellow these days. A can of plastic paint will take care of that-
Offline B67FSTB
« Reply #5 on: March, 29, 2010, 08:09:48 AM »
Word of correction : I did altern my batterytray to fit a ( i think) 27F standart battery
Online 6t6red
« Reply #6 on: March, 29, 2010, 08:21:14 AM »
Craig, last year I bought a Motorcraft 24 series from the ford dealership.  It is mostly black.
  Paul
Offline johnpro
« Reply #7 on: March, 29, 2010, 04:25:16 PM »
Get an Optima and paint it whatever color you prefer.  I don't like having battery acid in my engine bay, and never will again.
Offline monkeystash
« Reply #8 on: March, 29, 2010, 04:35:19 PM »
+1
-Ryan
Online RyanG85
« Reply #9 on: March, 29, 2010, 07:02:55 PM »
I'm using an Exide nascar select battery. Its all black. Been good for the past 4 years.
Offline MarkStang
  • Rubber Turnin' Virgin
  • Active Poster
  • Spindle Nutzo
Love your children
Offline d_ford
  • Active Poster
« Reply #11 on: March, 30, 2010, 09:08:34 AM »
I've had really good luck with Interstate batteries. The 24F I have in both of my 68's are black case.
Doug
Video of my fastback here. http://www.youtube.com/my_videos?feature=mhum
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #12 on: March, 30, 2010, 10:33:33 AM »
Read up on the Optima website and they look pretty good.
The group numbers that they list don't match up at all with 24 or 27.  Which Optima red top matches up to the group 24 size?
I guess my asking that doesn't help Craig, and while it does have a black case, the posts look like they are not spaced right to put on one of those AUTOLITE covers.
« Last Edit: March, 30, 2010, 11:16:13 AM by sigtauenus »
Sam
Member number 427
68 Coupe
Offline buening
« Reply #13 on: March, 30, 2010, 12:06:17 PM »
Craig you really need to add some color besides black to that engine bay.    :lol :lol
Custom Motor Mounts
T56 Conversion
Offline Fast68back
« Reply #14 on: March, 30, 2010, 01:35:46 PM »
My Optima is a red top, they had a $25 or $50 rebate when I bought it at autozone. It softened the blow a little.
Offline buening
« Reply #15 on: March, 30, 2010, 01:41:00 PM »
My Redtop was relocated to the trunk using a modified stock battery tray mounted to the passenger frame rail.  Just another idea....
Online lethal289
  • Steel Hoods Rule!
« Reply #16 on: March, 30, 2010, 02:49:47 PM »
I thought the idea for the optima is that they are gel filled, so Duanes little run in with acid would be a lot less likely to happen.  Am i wrong?  What are the other pros?
Offline jmlay
  • Quiet Type
« Reply #17 on: March, 30, 2010, 04:55:42 PM »
If you are looking for a "standard" type battery then I will not put anything but a Motorcraft in! I beat the battery in my Lightning for 8 years, discharged it fully several times, & it lasted. I had a 93 ranger I left the lights on for 3 weeks!!! One jump start, never charged on a battery charger, & it lasted for the 5 more years I owned the truck & was still going strong.
Offline buening
« Reply #18 on: March, 30, 2010, 04:57:07 PM »
I will agree with this.  My father's 95 Ranger still has the original battery in it and it has about 200k miles on it.  It's had all kind of battery drains and still going strong
Offline Starfury
  • My car HATES me
« Reply #19 on: March, 30, 2010, 05:43:17 PM »
You guys do know that Motorcraft doesn't actually make batteries, right?  There are only a few major battery companies, Johnson Controls Inc (JCI) and Exide are the two largest.  Most batteries are supplied by one of the two.  JCI batteries include Interstate, Optima, Die Hard, Duralast (Autozone), Super Start (O'Reilly), and Napa's batteries.  Exide seems to be losing ground.  I can't recall who makes Motorcraft or AC Delco batteries.
Tad H.
'67 fastback
331 stroker
3sp m/t
Offline AzPete
  • Classic...less
« Reply #20 on: March, 30, 2010, 05:46:10 PM »
I believe Johnson makes Motorcraft.
USAF/Ret.
7 Previously owned..66-07
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #21 on: March, 30, 2010, 06:23:56 PM »
Since the question got lost, for you guys with Optima's, which one fits the group 24 box up front?
Offline SAC69
  • Yak, Yak, Yak
« Reply #22 on: March, 30, 2010, 07:36:38 PM »
I bought a black battery from Kragen/O'Reilly's, peeled their black decal off the and placed a large "Autolite" on instead.
Tom
a.m.d.g.
Go Navy!
Offline apollard
« Reply #23 on: March, 31, 2010, 03:39:37 AM »
I'd just compare dimensions to make sure it will fit. Here's the chart for std battery types & dimensions. Compare with the Optima dimensions, and you're good to go.
http://www.rtpnet.org/teaa/bcigroup.html
Offline Starfury
  • My car HATES me
« Reply #24 on: March, 31, 2010, 06:36:25 AM »
The 34/78 Optima fits ok in my battery tray.  It's a little loose at the bottom, but with the riser plate it comes with, the top hold down keeps it from moving.  Better than having battery acid all over the place, eating out the already existing hole in the inner fender.
