Bought some 1 inch drop springs from NPD and was not happy with what it looked like on the car. The spring that came off was bad and it sits higher than this one. The front is set at 23 3/4 inches to the center of wheel well. The new one inch drop spring sets the rear at 25 inches. It swallows the tire just like the front but the exhaust is hitting at the brake connecting block. This just too low. The axle is just 1/2 inch away so it does not matter if the connecting brake block was there or not. I see the other spring on the other side sits just right. Is it possible that only one spring went bad on the car. it was sitting much loxer on the driver side when I took the shocks off.
Plan to go back to NPD and get standard leafs tomorrow.
