Author Topic: Last minute decision on Shag's paint scheme  (Read 726 times)
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« on: October, 10, 2008, 06:12:58 AM »
I shot a spray out card last night from the gallon of Highland Green that my painter bought followed by some clear coat, for my approval and I give it a thumbs up.
Paint scheme:
Exterior: Highland Green BC & CC
Trunk and hidden interior: Highland Green BC  (no CC)
Exposed interior (A pillars, dash, sterring tube, door panels):  Parchment BC (no CC)
Underside, wheel wells and engine compartment: Sems trim black
*Hood underside: Highland  Green BC.   Should I clear coat it??????
We hope to be base coating as early as tomorrow (Sat).
Later on we will shoot the rear interior panels parchment as well.
« Last Edit: October, 10, 2008, 06:14:48 AM by cmayna »
Offline daveSanborn
Re: Last minute decision on Shag's paint scheme
« Reply #1 on: October, 10, 2008, 06:57:12 AM »
Quote
I'd clear the underside of both the hood and deck lid.
Offline cmayna
  • DILLIGARA ?
« Reply #2 on: October, 10, 2008, 08:39:56 AM »
Dave,
My painter just said the same thing.    Too bad he can't pick up hot chicks the old school way.
Thanks
Offline JeffTepper
  • Cookie Pimp
« Reply #3 on: October, 10, 2008, 09:28:35 AM »
Quote
+1
Offline cmayna
  • DILLIGARA ?
« Reply #4 on: October, 10, 2008, 03:43:04 PM »
Jeff,
Can you and Lynn somehow switch positions in you avatar so I can first see her legs instead of yours?  Until then, thanks for the input.
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
« Reply #5 on: October, 10, 2008, 04:17:13 PM »
Clear coat everything nancy boy.
Why would you want base coat only on the interior? I would use single stage. I don't think base coat would be durable enough.
Offline daveSanborn
« Reply #6 on: October, 10, 2008, 04:37:47 PM »
Quote
See, I was thinking the same thing.  I can understand Craigs desire to have a low gloss sheen on certain areas, but applying only a BC doesn't offer very much durability.  The clear coat application is what provides the hardness/durability.  I'd think that the BC by itself would scratch very easily.
For the areas Craig mentioned where he'd like to have a low gloss finish, why not use a single stage urethane with a flattening agent?
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #7 on: October, 10, 2008, 04:50:24 PM »
I used acrylic enamel single stage for my trunk area and interior.  I agree that almost any single stage would be better than simply base coat.
Craig, step away from that hookah.
Panama City, FL
Offline Sluggo
    • www.StangFix.com
« Reply #8 on: October, 10, 2008, 06:53:21 PM »
Base coat is regularly used in trunk areas on newer cars. If used in an area with high usage and ultraviolet light I think the decision would be one that would carry some regret fairly soon.
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
« Reply #9 on: October, 10, 2008, 08:42:20 PM »
Craig,
I have to agree with everyone else.  If you're going to use a bc/cc, maybe George can find a "satin" clear just for the trunk & under the hood.
Is there such a thing as a "satin" clear that would have less gloss?
Mike
Offline Sluggo
    • www.StangFix.com
« Reply #10 on: October, 10, 2008, 08:57:48 PM »
Craig,
Yes. Typically called deadening agent.
Offline cmayna
  • DILLIGARA ?
« Reply #11 on: October, 11, 2008, 05:16:24 AM »
In Red, I shot base coat only on the exposed interior areas (doors, column, rear interior quarters & dash) and have had great results.
But,  I do agree with all of you about the concerns of durability and will be talking to George today about this.   It's been a real biotch finding the shade of parchment in BC/CC, having to tint it to my likings, so now I will need to re-address it in a single stage paint.   Yes I have some flattening agent that might be coming into play.
I'll report back at end of today after spending the day with the painter & paint supply shop.
I appreciate all your comments and concerns on this matter.  Sometimes a slap in the face is good medicine.
Offline cmayna
  • DILLIGARA ?
« Reply #12 on: October, 12, 2008, 12:54:54 AM »
Got this nasty cold and cant sleep  ~cuss
  Spent first half of Saturday with Shag and the painter.  His main painter overheard our discussion about dash paint and chimed in with " just mix some PPG DX685 (flattening agent) into your clear and shoot it over your base coat.  I happen to have a quart of it in my truck, pulled it out and he smiled.  George told me to go home and find the sheen that I like.  Meaning  "get the heck outta here" and practice shooting some sprayout cards.
Spent the afternoon and finally found a ratio of   3/4 : 1   (agent : clear) that gives me an sheen of something between egg shell and satin.   I did find a user bullentin that says the ratio will depend on the manufacturer of the clear so I might go back down today and steal some of George's clear for I know he doesn't used PPG.
Damn, 2 am.....back to bed
PS-The painter also mentioned a trick in bringing out the metallic in such paints is to mix a little flattening agent into the base coat.  It makes the metal flakes look a little more coarse. "Makes them pop" I think the phrase was.
Now back to bed
I need some TP.......... :binkybaby:
« Last Edit: October, 12, 2008, 12:58:54 AM by cmayna »
Offline garner67
« Reply #13 on: October, 12, 2008, 07:40:46 PM »
Now back to bed
... need some TP?  TP for your bunghole?
Offline cmayna
  • DILLIGARA ?
« Reply #14 on: October, 13, 2008, 08:22:50 AM »
Michael, what paint are you using for the textured part of your doors.  Eyes got 2 no.
