Author Topic: 65 partial outer wheel house  (Read 390 times)
Offline Dennis Harrelson
  • Active Poster
« on: March, 07, 2010, 04:12:34 PM »
Maybe a stupid question, but... Am I looking at this right?
Does it extend several inches above the trunk floor?
65 2+2, owned since '72
Granada Frt disc, Crown Vic Rear disc
1" Shelby Drop, 620s w/ 1 coil cut, F.R. spear-o-matic steering
Mustang Steve roller pedals, cable clutch, and power booster
T-5, 3.80 Detroit Tru-Trac
Horribly worn out 302 w/ leaky Holle
Online RyanG85
Re: 65 partial outer wheel house
« Reply #1 on: March, 07, 2010, 04:41:52 PM »
Yes and its a pile of crap. It is NOT a cut and fit piece. More like cut, reshape, rebend, fit and do a few more times before it becomes acceptable. I would look for the dynacorn complete outer well and cut what you need from that. STAY AWAY FROM AMERICAN DESIGNERS
Offline monkeystash
« Reply #2 on: March, 07, 2010, 06:38:01 PM »
I sectioned it and put in the lower part.
-Ryan
  • Active Poster
« Reply #3 on: March, 08, 2010, 07:48:04 AM »
OK. Thanks.
Online RyanG85
« Reply #4 on: March, 08, 2010, 08:11:55 AM »
How much of yours needs replacing?
  • Active Poster
« Reply #5 on: March, 08, 2010, 09:31:52 AM »
It looks like it needs pretty much all of the partial. I had trunk floors replaced some years ago, along with the usual rust work. The guy did a pretty good job bending up a piece for the bottom of the wheel house, but a sh!tty job welding it in, so I figured it'd be easier to use the partial than to try and salvage what's there and have to make a piece for above what he made. Plus he fixed a small lacy area on the inner house with filler, and I figured I could make that piece if I had something solid to attach it to. There's so much filler and sealer holding his piece in I'm gonna have to cut enough out to make it tough to re-use what he made.
Online RyanG85
« Reply #6 on: March, 08, 2010, 10:22:36 AM »
If you need most of it or all of it, I would get the full and cut what you need. Doing a small section like Ryan did, you'll probably be ok with the section.
Here are the pics from mine..
Believe me, it took tons of work to make them fit like they were supposed too. I would do it with sections form full ones if to do it again.
  • Active Poster
« Reply #7 on: March, 08, 2010, 10:57:16 AM »
What are the odds the full house fits any better than the partial, though?
Online RyanG85
« Reply #8 on: March, 08, 2010, 11:10:33 AM »
The Dynacorn full half has a much better stamping than the american designer brand. The AD is a heavier gauge with poor stamping.
