I posted this over at another site before I moved over here.
Here is a mod I did on my filler neck about 1 year ago. It was never installed because I went a differnt route.
My original plan was to run a return line into the trunk via the drain hole on the driver's side trunk. The filler neck was cut so it could pass thru the rear panel. It would not go in with the AN fitting welded on. This project started becuase I was adding an electric fuel pump to my carbed car.
I am posting this just to give people an idea on how it can be done. In the end, I went with a fuel sender that had a return built in.
BTW, If anyone wants this PM me. It is for sale cheap.
