Author Topic: best method for motor/trans instal in a 65?  (Read 948 times)
Offline 65-408
  • Active Poster
« on: January, 14, 2010, 06:37:09 AM »
I believe I took them out together, but it wasn't pretty, there was a bunch of scraping and banging...  I'm sure I could have been more careful, but am wondering what is the preffered method, together or apart?
408W, Tremec TKO600, 9" Traction-Lock w/ 3.50 gears and Hiedt's 4-Link, 17" Vintage 45's w/235/45/17 all around
Online Fast68back
Re: best method for motor/trans instal in a 65?
« Reply #1 on: January, 14, 2010, 06:48:41 AM »
Together, jack the rear end as high as you can get it and make sure your engine hoist has a decent length chain and load leveler. I think Dne' has a post with pictures when she installed the drivetrain in her '67.
Offline buening
« Reply #2 on: January, 14, 2010, 06:53:34 AM »
Jacking the rear end and the load leveler is key.  One person below the car to guide the tailshaft of the trans and another operating the cherry picker.
Custom Motor Mounts
T56 Conversion
Online Fast68back
« Reply #3 on: January, 14, 2010, 07:02:30 AM »
Unfortunately, the pics dont seem to work anymore (stupid photobucket)
http://www.stangfix.com/testforum/index.php/topic,1689.0.html
Offline silverblueBP
    • My 66 2+2
« Reply #4 on: January, 14, 2010, 07:10:15 AM »
Yep, what was said above. It only takes 2 people (*) to install the engine w/ the tranny installed. Might need to remove the shifter and keep the plug in the output end of the transmission if it has the fluids in it.
*note* unless it's Shag, then it takes 6    :ecit
-Mark-
CarDomain
Online Fast68back
« Reply #5 on: January, 14, 2010, 07:24:26 AM »
Didn't Dne' do it by herself? Not sure what that says about the CA "guys".....
Offline 65-408
  • Active Poster
« Reply #6 on: January, 14, 2010, 08:23:37 AM »
together it is, thanks for the heads up on jacking the rear, seems so obvious, but wouldn't have done it...
Offline B67FSTB
  • President, StangFix Belgium
« Reply #7 on: January, 14, 2010, 08:45:07 AM »
 :lol :lol :lol :lol :lol :lol :lol :lol :lol :lol :lol
COULDN'T RESIST !!!
Bruno
Offline 65fast
  • Active Poster
« Reply #8 on: January, 14, 2010, 09:03:42 AM »
Another vote for together, I do not think a leveler is necessary though.  I have installed mine a handful of times with out a leveler,  just offset the hook in the chain.
Exercise Your Mustang
306
AFR 185's
FTI Roller .568/.570 - 218/230
Weiand Stealth
Toploader
9" 3.50 T-Lock
Offline gotstang
« Reply #9 on: January, 14, 2010, 11:14:44 AM »
I've always done it with the front on ramps, install the engine/trans/headers as one piece and gradually backed the car up as we slid the engine in.
Start a Coupe coup!
'66 Coupe 289 & 3 speed 5.0-AOD, here we come!
My Webpage & Tech pages
Offline buening
« Reply #10 on: January, 14, 2010, 11:46:14 AM »
Is this a rear engine car?  :lol  Sounds backwards of the way it should be.
Online Fast68back
« Reply #11 on: January, 14, 2010, 11:47:52 AM »
Good, I'm not the only one. I was sitting here trying to figure that one out.
Offline Tony R
« Reply #12 on: January, 14, 2010, 12:10:33 PM »
I have never installed with the engine and tranny together.  I always do it by myself though so i put in the motor and it is nothing to heft the tranny in place from the bottom.
Offline lethal289
  • Steel Hoods Rule!
« Reply #13 on: January, 14, 2010, 12:15:39 PM »
Together with the load leveler is the preferred method.
And the back in the air helps a lot.  I cheated and used a 4 post lift to get the back up.  Put some towels over the shock towers just in case.
Online Fast68back
« Reply #14 on: January, 14, 2010, 12:21:36 PM »
Pretty damn impressive Jake, you did it with the export brace installed.
Offline lethal289
  • Steel Hoods Rule!
« Reply #15 on: January, 14, 2010, 12:31:27 PM »
Yes sir, went right in without a hitch.  Even left the Hipo manifolds on. Now getting the motor mount bolts in were another story.  They took a little persuasion.  Having a friend with an awesome personal home garage is a plus.
I did all the prep work (sand blasting painting, wiring etc..,) at my place.  Then moved the car to his to use the lift for the motor / trans install, brake work, fuel lines etc... Hardest part of the whole thing, was pushing / walking my car to my friends house to do the install.  Traveled about 3 blocks, with one pain in the ass hill.
Offline apollard
« Reply #16 on: January, 14, 2010, 12:36:04 PM »
FWIW, I've done it both ways on mustangs (probably 5-6 times), and now I only do it separated. No big interference issues from export brace, steering, manifolds, or getting the engine mounts to line up when you do it separated. Not that hard to hook up the trans & engine IMO, and the trans is easily lifted with a floor jack and the plywood piece referenced in the post.
Now, I've done some BMWs, and there it is much easier to drop them together- but the assembly is much more complicated and difficult to do in the car with the BMW.
I just don't find that much advantage in effort or time for a mustang, though.
Online Fast68back
« Reply #17 on: January, 14, 2010, 12:46:43 PM »
Sluggo and I had planned on installing mine as an assembly, but I did not have enough chain or a leveler with my rental hoist, so it had to come apart.
Offline Tony R
« Reply #18 on: January, 14, 2010, 12:51:51 PM »
I don't like to use a jack to install the tranny.  I cant feel it go in so I fight it more with the jack.  Lethals garage setup is nice.  All that I have is a bunch of redneck engineered crap to work with.
Offline gotstang
« Reply #19 on: January, 14, 2010, 03:13:55 PM »
Jeez, I'm a retread today.... I knew Jake's picture looked farmiliar somehow, took a while to dawn on me that I explained it completely bass-ackwardly.
    • My 66 2+2
« Reply #20 on: January, 14, 2010, 06:17:39 PM »
Real men OWN their own hoist/cherry picker, just say'n.
Offline AzPete
  • Classic...less
« Reply #21 on: January, 14, 2010, 06:20:10 PM »
We won't mention the PT passing problem........or the shirt....... :lol
USAF/Ret.
7 Previously owned..66-07
    • My 66 2+2
« Reply #22 on: January, 14, 2010, 06:28:26 PM »
Hey now, I'll be proud to wear that shirt on the track while running WFO  :pbj
and as a bonus, everyone gets to see the  :!!
Offline lethal289
  • Steel Hoods Rule!
« Reply #23 on: January, 14, 2010, 06:41:04 PM »
Way to go, you guys scarred the OP off.
Offline guruatbol
  • Grumpy Old Fart!
« Reply #24 on: January, 14, 2010, 06:43:31 PM »
I bought my cherry picker to build my lift.  It wasn't that expensive and it is here when I need to pull the engine on the 65.
