Female pins for turn signal connector plugs are a problem. The official tool removal tool is for the Commercial Mate N Lock 0.080" system: Tyco/AMP Contact Extraction Tool 465644-1, designed circa 1962. I bought it, and it promptly broke on me due to cheap pot metal construction. Here's what I do:I took a small flat-heat jeweler's screwdriver, and used a bench grinder to remove 1/2 of the thickness, leaving one side flat and the other side curved. I use this tool all the time to remove both male and female pins now. The trick is that the locking tab is 180* away from the joint line (almost always visible where the two sides of the pin come together to form a cylinder) and wedge the screwdriver (flat side toward the pin). It works for me!
Yeah, doing it in the car will be a bitch...it's bad enough on a workbench.I'm surprised the Metal Alloy stuff was bad; they have an excellent reputation and crimping wires onto these pins is trivial with the right part: Tyco/AMP Crimper, part 58515-1 for about $216.00
NPD sells a combination tool that might do the trick. Look for part number 957-2. $13.95 on page 248 of the 2010 catalog.
It's absolutely worthless, and it doesn't fit any Ford pins enough to do any good. Ask me how I know.
