Author Topic: What is your take on this?  (Read 577 times)
Offline 65-408
  • Active Poster
« on: January, 11, 2010, 10:43:54 AM »
The claim is that the 2 row aluminum radiator (with (2) 1" wide rows) is better than a 3 row (with (3) .531" wide rows), seems to make sense to me, what do you guys think...
http://cgi.ebay.com/ebaymotors/NEW-Mustang-66-65-64-Aluminum-Radiator-V8-Conversion_W0QQcmdZViewItemQQhashZitem5ad61526b9QQitemZ390138767033QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
408W, Tremec TKO600, 9" Traction-Lock w/ 3.50 gears and Hiedt's 4-Link, 17" Vintage 45's w/235/45/17 all around
Offline daveSanborn
Re: What is your take on this?
« Reply #1 on: January, 11, 2010, 10:50:42 AM »
Quote
Math.
2 x 1" = 2"
3 x .531" = 1.593"
Larger flow capacity wins.
Offline RustyRed
« Reply #2 on: January, 11, 2010, 10:55:46 AM »
I'm running something similar with a 302 and have not had any problems with heat.
I have problems with mine being cold natured to the extreme but not a single worry of over heating....
Coupes rule and Mark drools
Offline lethal289
  • Steel Hoods Rule!
« Reply #3 on: January, 11, 2010, 12:20:20 PM »
Math.
2 x 1" = 2"
3 x .531" = 1.593"
Right idea, Wrong math when dealing with tubular pipes.  Your dealing with pipe area. pie x radius squared
for 1" its   = 3.14 * .5 * .5  x 2 pipes= 1.57
for .531 its = 3.14 * .2655 x .2655 x 3 pipes = .6640
Thats assuming that the lengths of the pipes are the same.  the 1" one is more then twice as good.
Offline pprince
  • 5F09C332634
    • Collector Vehicle Appraisals
« Reply #4 on: January, 11, 2010, 12:46:29 PM »
Since the channels aren't round you would have to do some calculus to determine the volume.
1965 Mustang 2+2
prince-cva.ca
Offline daveSanborn
« Reply #5 on: January, 11, 2010, 01:06:19 PM »
I hope to god you're not talking to me......  I have to think real hard just to remember how to spell calculus, nevermind actually use it.
Offline lethal289
  • Steel Hoods Rule!
« Reply #6 on: January, 11, 2010, 01:20:31 PM »
Theres one more very important determining factor, its the length of each channel.  We are just assuming the lengths are the same and the diameter is changing.  To much of an unknown to say for sure.
Offline silverblueBP
    • My 66 2+2
« Reply #7 on: January, 11, 2010, 02:05:07 PM »
Stop it, you're making my head hurt.
I need a beer.
-Mark-
CarDomain
Offline PJ Moran
  • Active Poster
  • Before...
« Reply #8 on: January, 11, 2010, 03:24:50 PM »
That ain't it, either.  It's about surface area of the tubes, not the cross-sectional area.
But, since the tubes are about the same height (and very "short"), with only the width changing, the original calculation is closer to correct than you might think.
Bottom line is, the wider aluminum tubes do a much better job of heat transfer than the narrow brass versions.  Aluminum is a better conductor of heat than brass is, too.  So, it's better on a coupla levels.
Aluminum is susceptible to electrolisis, though, so it's not without its shortcomings.
After...
Here's a link to my gallery.  Check it out!  http://www.stangfix.com/testforum/index.php?action=gallery;su=user;u=383
Offline pprince
  • 5F09C332634
« Reply #9 on: January, 11, 2010, 04:46:33 PM »
All I remember from math class is pie are round and cake are square
Offline SELLERSRODSHOP
  • Nick Jr.
  • I smell smoke....
« Reply #10 on: January, 11, 2010, 09:05:24 PM »
unless it's a bundt cake.... when it comes to figuring that out, i'm with mark, time for a beer... :lol
Offline 65-408
  • Active Poster
« Reply #11 on: January, 12, 2010, 05:07:08 AM »
got an answer on tube spacing, it is 3/8", same as I have seen on the 3 and 4 row versions.  I agree with the above that the resulting flattened tube width comparison is a good comparison of effective contact area...  so given that the tube spacing is the same and the width of the radiator is the same, it seems like the 2 row is the better design...
Are traditional radiator tubes copper or brass?  Aluminum conducts heat 2X better than brass, but it is only about half of copper...
Offline B67FSTB
  • President, StangFix Belgium
« Reply #12 on: January, 12, 2010, 07:56:56 AM »
Surface and material , thats all about it when it comes to cooling
Bruno
Offline 66gt350
  • Ah like me sum gunz...
« Reply #13 on: January, 12, 2010, 08:12:20 AM »
Don't forget it's not only the surface area of the water tubes, but the surface area of the fins.
-rob "Ricky Bobby"
Offline johnpro
« Reply #14 on: January, 13, 2010, 02:30:18 PM »
One thing not mentioned by all the math geniuses around here ... that radiator says for '65-'66, yet the outlet is on the left side.
In other words, it's only for MODIFIED '65-'66 cars.
