Author Topic: Starter won't fit the Cleveland  (Read 590 times)
Online cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« on: January, 09, 2010, 08:22:36 PM »
Does anyone have an extra starter laying around which they can measure the main case diameter?  I bought a supposed 351 cleveland starter which apparently has the same bolt pattern but when aligning up to go in, I see the front portion of the starter's case it hitting the oil pan.  It is so close but yet "no soup for me"
Offline daveSanborn
Re: Starter won't fit the Cleveland
« Reply #1 on: January, 09, 2010, 08:29:21 PM »
That's weird Craig.... are you sure you're not trying to use a Windsor starter or something?  I never had any problems mounting up a starter on the Cleve in my '68.  Fit was perfect.
Online cmayna
  • DILLIGARA ?
« Reply #2 on: January, 10, 2010, 06:36:18 AM »
NAPA says the starter I got is for a cleveland with a Manual tranny.    Wouldn't a regular say 65/66 mustang starter fit?    I'm going to take the starter back to NAPA today and see if they have my old one I gave up for a core charge.  I'd like to measure the diameters.
Online Fast68back
« Reply #3 on: January, 10, 2010, 08:50:27 AM »
When I swapped my toploader for the T5 I could not use the same starter, it would not seat all the way in. I knew the late model mini starter would work, so thats when I swapped them.
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #4 on: January, 10, 2010, 09:26:10 AM »
It hits the oil pan?  Or the bell housing won't allow it to go all the way in?  If the latter, remember that almost all SBF's have their starters reversed for automagic and manual trannies.  The store-bought manual starter won't fit into the manual bellhousing, as it really is an automagic starter with a longer snout.
Panama City, FL
Offline Sacbill
  • Ever Waddin'
  • You can't spell bass without "ass"
    • JackWagon - My Band
« Reply #5 on: January, 10, 2010, 07:52:57 PM »
I recently got a '65-style fuel pump from NAPA that didn't fit properly on my small-block (Outer edge of diaphragm plate push up against oil pan).  Kragen didn't have the right one either.  Maybe the same 'non-fit' problem is bugging you, too?
Bill | '67 Vert | '68 Coupe
Follow the '67 build...
Lessons:
1. Always Check the Ignition Switch First, DUMMY! (Aug '11)
Offline guruatbol
  • Grumpy Old Fart!
« Reply #6 on: January, 10, 2010, 08:05:41 PM »
Craig, when I did the T5 and the TKO swap I had to get new starters.  The one in the book at NAPA is wrong.  Um, when I get back in town I'll look at the one on the TKO, it is on the lift right now and see what it is.  I know I don't have a Clevo, but it should be a starting point.
I should be back on Tuesday.
Online cmayna
  • DILLIGARA ?
« Reply #7 on: January, 11, 2010, 06:45:30 AM »
I'm going to contact  Bruce of ModernDriveline to see what he says.  I've heard that a mini starter for a 96 Thunderbird takes care of my problem but they're not cheap.
Offline gotstang
« Reply #8 on: January, 11, 2010, 10:19:23 AM »
You might want to visit your local wrecking yard. Ford used ministarters that will fit most conventional engines from 1991 until ~2005. All you should need is a starter from something 2WD and manual trans. Cars with a "conventional" engine like a 3.8/4.2 V6 or 5.0L are best, heck a 300 I6 starter should fit as well.
Start a Coupe coup!
'66 Coupe 289 & 3 speed 5.0-AOD, here we come!
My Webpage & Tech pages
Offline Sacbill
  • Ever Waddin'
« Reply #9 on: January, 11, 2010, 09:10:30 PM »
Sounds like a job for crustycurmudgeon!
Offline crustycurmudgeon
  • Mr. California Black Plate
« Reply #10 on: January, 11, 2010, 11:16:37 PM »
Well, I can't easily go shimmying under junkyard cars on my lunch break without getting dirty.  I only occasionally go on the weekend.
Frank
Online cmayna
  • DILLIGARA ?
« Reply #11 on: January, 12, 2010, 09:05:53 AM »
Yeah right Frank.  Then how come you have had all your mail rerouted to Pick-n-nose, San Jose, CA.??????
Bruce of Modern Driveline sent me an email saying that if I want to make it easy just get a starter from a 91-95 Mustang 5.0L. They are plentiful and small.
Online Fast68back
« Reply #12 on: January, 12, 2010, 11:35:39 AM »
Yup, Thats what I have, picked it up from Manny, Moe and Jack (Pep Boys), got the lifetime warranty, the second time..  :cry
Offline napaguy
« Reply #13 on: January, 12, 2010, 12:24:48 PM »
Craig,
I have said starter brand new that I will probably never use...send me a pt if you are interested.
Offline guruatbol
  • Grumpy Old Fart!
« Reply #14 on: January, 12, 2010, 02:43:17 PM »
Craig, that is what is under my 65.  Prolly the 67 too.
