Author Topic: Update: Freakin squeak still with me - go to last posts  (Read 1122 times)
Online cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« on: September, 11, 2008, 11:51:53 AM »
Red has developed this squeak which I thought was either the U-joint or rear wheel bearings, which both have been replaced and the squeak is still there.  It seems to be a wheel revolution generated squeak when I'm driving around 35+ but fades away when I apply brakes.
What I totally forgot was to lubricate the edge of the brake shoes where they get real close to the backing plates in back.  Can this be the culprit?
The only other area I have not looked at is the front bearings. We have put around 14k miles on these bearings.
« Last Edit: September, 14, 2008, 05:29:10 PM by cmayna »
Offline daveSanborn
Re: Can it be the brake shoe rubbing against the backing plate?
« Reply #1 on: September, 11, 2008, 12:01:25 PM »
There's an easy way to tell..... pull the drum and take a look.  If the shoe has been rubbing/squeeking on the backing plate, they'll be fresh evidence of that.
Online cmayna
  • DILLIGARA ?
« Reply #2 on: September, 11, 2008, 12:33:33 PM »
That's what I'm going to do tonight.  Besides I need to take pics of Red's brake assemblies so I can have a reference pic when I start assembling Shag's rear brakes.
Offline daveSanborn
« Reply #3 on: September, 11, 2008, 12:40:33 PM »
Craig,
Inspect for a ridge worn into the backing plate that could be hanging up the brake shoe from retracting.... This would cause the shoe to stay in contact with the rotating drum and produce your "squeek".  Applying the brakes would of course stop the squeek.  You may have nailed this problem.
Online cmayna
  • DILLIGARA ?
« Reply #4 on: September, 11, 2008, 12:54:31 PM »
Sure glad I only need to look at your frightening mug just one time per post  :rof
Online cmayna
  • DILLIGARA ?
« Reply #5 on: September, 11, 2008, 04:45:46 PM »
Dave, though I have not driven the car yet, I agree that the very freshly worn grooves on the driver's side is a sign that this is the issue.  For now I just greased these contact points but as soon as winter comes along when I'm not so apt to want to drive the car, I'm replacing or fixing them.
Can I simply weld in the grooves and smooth it out afterwards?  Wish I had done this before.  Just check Shag's backing plates and they look factory fresh.  Whew.
Thanks for the tip.  I owe you a refreshment drink whenever we meet.
Offline daveSanborn
« Reply #6 on: September, 11, 2008, 05:37:39 PM »
Craig, the standard method of repair is to simply grind the ridge smooth and repaint.  If it's worn REALLY deep, I guess laying a bead into the groove and then grinding smooth would be fine.  The key to the repair is "smooth"... leave nothing for the edge of the shoe to hang up on in the future.  One little burr will start the whole "groove" process all over again.
« Last Edit: September, 11, 2008, 05:41:38 PM by daveSanborn »
Offline AzPete
  • Classic...less
« Reply #7 on: September, 11, 2008, 06:23:30 PM »
I have seen the plates with holes worn in them. A bit of welding and a touch of a grinder and they were good as new.
I have seen a brake drum flex causing a squeak at the axle center hub area.
USAF/Ret.
7 Previously owned..66-07
Online cmayna
  • DILLIGARA ?
« Reply #8 on: September, 11, 2008, 06:33:07 PM »
Job security for this winter.
Offline Starfury
  • My car HATES me
« Reply #9 on: September, 12, 2008, 08:08:05 AM »
Want to do mine, while you're at it? :D
Tad H.
'67 fastback
331 stroker
3sp m/t
Online cmayna
  • DILLIGARA ?
« Reply #10 on: September, 12, 2008, 08:24:16 AM »
I decided to rip into it starting tonight.  I'll weld in the grooves and smooth it out.  This will be done while the backing plate remains on the car for I don't want to disconnect the brake lines.
Tad, drive up here and I'll do your.
Offline Starfury
  • My car HATES me
« Reply #11 on: September, 12, 2008, 12:13:46 PM »
lol....thanks, but i was kinda joking:)  Mine definitely need to be welded, and I'm not sure I want to put the effort into an axle I'm going to ditch in the next 2-5 yrs anyway
Online cmayna
  • DILLIGARA ?
« Reply #12 on: September, 14, 2008, 06:04:36 AM »
Update: Dave, I think that was the problem.  The lower contacts were pretty well shinny grooved on the drivers side so I simply ground them down, polished them up, paint and grease afterwards. Cleaned up the passenger's side as well.  Took the car out afterwards and can't find the squeak.   Next weekend a bunch of us are going to MustangsPlus meet so I'll put it through a good test.
Offline Starfury
  • My car HATES me
« Reply #13 on: September, 14, 2008, 07:09:45 AM »
Really?  I'm from Stockton:)  I went to their last meet almost on accident.  I happened to be in town and realized the show was going on, so I dragged my mom out there and picked up my rear leafs while I was at it.
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #14 on: September, 14, 2008, 08:18:31 AM »
AzPete and I believe that lack of grease on the backing plate may be the cause of my rear brake problems.  Yesterday, we put a grinding disk against the backing plate, applied some grease, and put things back together.  The brakes seemed to rotate a lot easier now.  Time will tell if the adjustment system works.
Panama City, FL
Online cmayna
  • DILLIGARA ?
Re: Update: Freakin squeak still with me - go to last posts
« Reply #15 on: September, 14, 2008, 05:33:27 PM »
It took my wife to say to me "Honey?  You do know that Red still squeaks, dont you?"    Today I showed the GTO locally and realized they had room for Red, so my wife drove Red to the show. Show went great and upon my return home, she drops the bomb.
Recap:  Ujoints and rear axle bearings replaced. Backing plates ground down at pads that the shoes touched.
Still sounds wheel revolution origin.
Front wheel bearings?
Dang!
Offline AzPete
  • Classic...less
« Reply #16 on: September, 15, 2008, 08:04:44 AM »
Do you have disc brakes up front? If so, could it be a warped disc? If not, get more power to the speakers..... I doubt that it is a wheel bearing. Try jacking up each wheel ans spinning it by hand. You may be able to feel a bind or hear a rubbing sound.
Online cmayna
  • DILLIGARA ?
« Reply #17 on: September, 15, 2008, 08:12:00 AM »
Warped rotor?   That's a great idea for Red does have discs up front.  Will check it tonight.
Online cmayna
  • DILLIGARA ?
« Reply #18 on: September, 15, 2008, 12:43:39 PM »
Jacked up the front today and both wheels spin without a squeak.  I assume the disc pads slightly rub against the rotors constantly when non braking?  For there is a slight resistance of pad rub.
Regarding rears.  Both rear drums do rub a little bit against the shoes. Like maybe one spot per revolution.  Tried getting either one of them to squeak and nothing.
What a PITA.
Offline Midlife
  • DOM
« Reply #19 on: September, 15, 2008, 12:49:12 PM »
Check for any rubbing of the driveshaft against the e-cables or other items.  Not much else back there to squeak...Can you put t up on jacks on the rear and rotate the driveshaft and rear end together?
Offline AzPete
  • Classic...less
« Reply #20 on: September, 15, 2008, 01:08:06 PM »
Does it start making noise when cold or does it seem like the noise producing item needs to be warm? Does it change speed with the speed of the car or remain the same speed/tempo?
Does making a corner in either direction change it?
Does applying the brakes change it?
Is it only noisy when the wife is in the car?
Online cmayna
  • DILLIGARA ?
« Reply #21 on: September, 16, 2008, 05:44:25 AM »
Pete, If it was that simple, I'd just duct tape her  :binkybaby:
It is not a consistant squeak.  It typically happens around 25-30mph with no brakes on and after a few minutes of warm up.
Midlife, I will look underneath once again after I jack up the back end but I don't think anything is touching the driveline.
Offline Starfury
  • My car HATES me
« Reply #22 on: September, 16, 2008, 08:22:15 AM »
Do you have a dial gauge?  I'd stick one on the front rotors and check for runout.  If you're lazy/don't have one, you can take it to a chain auto shop and have them do a 'free' brake inspection for you (usually costs like $10-15 if you don't have any work done).  It's possible the rotors are just warped enough to come into contact with the pads while the brakes aren't applied, causing the pads to glaze over slightly, which in turn causes the speed-related squeak.
Online cmayna
  • DILLIGARA ?
« Reply #23 on: September, 16, 2008, 09:47:58 AM »
Do we know what the run out or warp tolerance is?  Yes I do have a dial gauge.
Offline Starfury
  • My car HATES me
« Reply #24 on: September, 16, 2008, 12:22:14 PM »
Any more than .003" runout is out of spec for pretty much anything, and I believe thickness variation spec is anything more than .002"
« Last Edit: September, 16, 2008, 12:44:46 PM by Starfury »
