Linux Mint 11 Rulez....
I've been reading the replies here because I need new springs and have been debating doing it myself or having a buddy at a local shop do it for me.
I have never removed the rear end from under the car unless I was doing other work. No need to have to re-bleed the brakes and all. After soaking the bolts for a couple days, I supported the car on stands, took pressure off the rear springs by lifting it with a jack, unbolted the rear shackles, then the u-bolts at the axle, then the front spring mount bolts. Removed one spring and replaced. Then went to the other side.The front bolts may not slide out no matter what due to wear. You may need to cut them along the spring edge using a saws all.
Thanks for the complements on the car. Since that pic, I have applied the C stripes. The purchase story is on the VMF, but I can link it or post here if anyone is interested.
+1
Thanks, it's a factory Turbo, with the heavy duty R151 5 speed tranny.Probably TMI (too much information), huh?
I used a torch on the first one. Not a good idea. The rubber bushing caught fire. Lots of of gooey hot smelly rubber everywhere. And smoke, lots and lots of smoke.
When I went to help Brian (Havok1) strip his car last Winter his leaf spring bolts were stuck pretty good. I believe we used a 3-5 pound mallet and kept beating the heck out of the bolts. Both of them eventually broke free, but it wasn't without a lot of effort/hammer blows.
