Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Home
Help
Login
Register
StangFix.com Forums
Forum
1964 1/2 through 1973 Mustang Boards
Engine and Drivetrain Board
Ford racing boss 302 crate motor
Random Image from the Gallery
Latest Victims
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Ford racing boss 302 crate motor (Read 657 times)
classicdoug
Active Poster
I get to restore cars for a living!
on:
December, 12, 2009, 06:32:39 PM »
Can someone look at this and tell me a little info. I'm a body/paint guy trying to buy an engine for my 65 fastback. It will be a weekend driver that I'm planning on putting Mass-Flo EFI on. My main objective is to have an engine that will last me forever and will start every time I turn the key. I'm not looking to melt the tires. However, I've come across this Ford crate motor on ebay from a Ford dealership. They are selling it for $6180. The Ford racing website lists it at $8790. Even getting parts discounts since I own a body shop, I can't buy it this cheap from my local motorsport dealer in Houston. Let me know what you think. Also, it mentions Z heads. Will headers that fit a regular 5.0 or 302 work on the Z heads.
http://cgi.ebay.com/ebaymotors/5-0L-302-CID-SMALL-BLOCK-390HP-Z-HEAD-CRATE-ENGINE_W0QQcmdZViewItemQQhashZitem3348dbb130QQitemZ220265689392QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Thanks,
Doug
Logged
Fast68back
Administrator
Shutup Already
You want fries with that?
Re: Ford racing boss 302 crate motor
Reply #1 on:
December, 12, 2009, 06:40:36 PM »
Thats not a "boss" block, its a standard 302 block, with aluminum Z heads. It is a good motor, but not one of the new "boss" blocks.
Its odd, the Ford Racing PN they list does not match up to anything. The HP and torque the list match up to the Boss crate engine, but they do not mention the boss block in the ad.
Quote
FORD RACING P/N: M-6007-Z50Z
The PN should be M-6007-Z302Z*
Last Edit: December, 12, 2009, 06:49:06 PM by Fast68back
Logged
classicdoug
Active Poster
Reply #2 on:
December, 12, 2009, 06:47:57 PM »
Now I see the difference. All of the numbers I was comparing to the Ford Racing website looked the same, except the Boss part. That definitely explains the price difference. I new it was too good to be true! Even so, how does that engine look for my application?
Thanks,
Doug
Logged
Fast68back
Administrator
Shutup Already
Reply #3 on:
December, 12, 2009, 06:53:39 PM »
It would still require some work to use in a late model. New pan and oil pump. The timing cover most likely is not setup for an oil dip stick, you mentioned EFI so you would be OK without the fuel pump eccentric and not having the opening for the fuel pump. I believe the water pump is reverse rotation as I imagine its setup for a serpentine. You would still need a distributor as well. AND i don thing the HP and torque values listed would be correct. I think you could find a similar deal (price) for a more drop in type engine.
Logged
classicdoug
Active Poster
Reply #4 on:
December, 12, 2009, 06:55:24 PM »
Exactly the info I needed.
Thanks a lot.
Doug
Logged
MarkStang
Rubber Turnin' Virgin
Active Poster
Spindle Nutzo
Reply #5 on:
December, 13, 2009, 04:24:43 PM »
Hello Doug, If you want a turn key motor (totally complete true drop in ) from experienced people then check this out. I received mine mounted on a crate, dropped it in , instant perfection.
Just a thought to take away the worries.
[admin]Are you missing a link?[/admin]
Last Edit: December, 13, 2009, 04:26:11 PM by Fast68back
Logged
Love your children
classicdoug
Active Poster
Reply #6 on:
December, 15, 2009, 06:54:56 PM »
Yes, please post the link!
Thanks,
Doug
Logged
MarkStang
Active Poster
Spindle Nutzo
Reply #7 on:
December, 15, 2009, 08:04:36 PM »
This is the link
http://www.enginefactory.com/Ford_performance_engine_choices.htm
The following is what I got from them
302/350HP
Intro to this video: The Video Link is at the end, the following is about the Engine.
It was done this summer before, during and after the "TGE" (The Great Exodus). If there is a "Dark" side and a "Light" side , I started seeing the light of the dark side on October 3rd 2008 with an inside whisper when I wrote that I noticed some changes were a happening. I post this to my new home for members that may have missed it over there.
The video was done for VMF as an attempt to get more members involved with video.I looked and did not find an "Audio" or "Video" room here...Yet... :) I think we were made for pictures and video, otherwise "Playboy" would never have employed photographers. the video captures the 2nd start of the engine. The actual first start fried my starter because I wired the ignition per Ford diagram (two wires were wrong don't have a clue why mine needed switching) The engine is a crate "True Turn Key" from
TheEngineFactory.com
350HP
Right or wrong I can tell you the Engine sat in that box for almost 2 years. An engine that was built by people better than I. This Engine was broke in at the factory for almost an hour using the standard break in procedure they use, video taped and sent to me when done. The Engine was payed for in payments over a two year period. This enabled me to afford to lock in a price that I knew would rise. 7200.00 or so is what I paid. This price included the Billet Serpentine
Precision machined 302 roller block
Nodular cast iron crankshaft
Shot peened & stress relieved connecting rods with 190,00 psi hardened bolts
Hypereutectic federal mogul 9.5 to 1 compression
Speed pro chrome Moly piston rings
3 piece steel double roller style timing chain
Hydraulic steel roller camshaft delivers mid-range horse power and great low end torque
New Melling oil pump and screen
Edelbrock rpm aluminum heads 60cc combustion chamber with bronze guides
stainless steel swirl polished intake valves
stainless steel swirl polished exhaust valves
Hard seats for unleaded or regular fuel
Heavy duty 1.45 diameter valve springs, 7 degree locks
Champion spark plugs gapped and installed
Comp cams roller tip rockers
New heavy duty chrome Moly push rods
New chrome front sump 5 quart oil pan
Timing chain cover with scale
Chrome baffled valve covers
Heavy duty automatic flywheel
New Edelbrock performer rpm dual plane intake manifold
New 4 barrel 650 cfm Edelbrock avs carburetor with electric choke
Electronic ignition distributor. 1 wire hook-up 45,000 volt coil pak
45 degree water temperature thermostat housing
8mm Accel silicone wires
New chrome thermostat housing
New fuel and water pump
Chrome 1 wire 100 Amp Alternator
I replaced with 3G Alternator Mod
Chrome dip tube and dipstick
New chrome Moroso air cleaner with pcv ventilation system
New fuel lines and gas filter
Hot run tested includes setting initial and full timing advance
Video footage shown of your engine in test stand
Blue
printed, assembled by ASE technicians
Crating and packaging at no extra charge.
I know an Engine like this can be done cheaper at home. I do not have the correct tools , Knowledge and specs to have done this properly and correctly. What I do know is that when it came time to put her in and start her, she would be correct and work for sure. That is what I paid for and it paid off. In the Video you will here high RPM's of the auto choke (not connected electrically yet) , this assured that lubrication started as quickly as possible.
http://www.youtube.com/user/markstang1965#p/u/2/MNnrnO2oY_E
Logged
Print
Pages: [
1
Go Up
« previous
next »
StangFix.com Forums
Forum
Powered by
EzPortal
