Author Topic: 1970 - Wheel Size  (Read 1644 times)
Offline Mach1ne
  • Track Monkey
Re: 1970 - Wheel Size
« Reply #50 on: December, 10, 2009, 04:59:30 PM »
...sort of. The rim diameter and backspace are just as important... The idea is to get MORE tire width than stock. With a larger diameter rim, you get to run extra backspacing and extra wheel & tire width, since everything tucks inside the wheelwell better. Yes, the overall diameter stays constant, but extra width is certainly possible with the right combination. It's all a juggling act...
Try fitting a 255 section 14" tire on an 8" wide wheel on the front and you'll see (it won't fit). Yet, with a 17x8 wheel (4.75 BS) and 255 tire, you'll have room to spare.
With that said, some people prefer the look of taller sidewalls, or run a smaller OD tire for a lower CG and less rolling inertia. All depends on what you want, budget, and how serious you are.  :)
With ALL that said, you won't find a budget 17" solution... Just starting out, I'd get a cheap set of 15x7 4" BS wheels, some decent 235/245 /50/15 tires and get out there and work on improving the nut behind the steering wheel...  :ecit
Okay back to the wheel discussion.
Bob, you think that I should go with 17x8x4.75?
Jeremy's 17x8x4.5s do not leave much clearence on the front.
DodgeStang's charts so that I should be fine with a 245/45/17 with a 17x8x4.0.
Do you think that a wheel shop in KC would have a wheel with tire to loan me to confirm what will work.
I was thinking about the wheel shop down from me on Johnson Drive.
My other option would be to see if Jeremy will loan me his two front wheels for a day.
Thoughts?
« Last Edit: December, 10, 2009, 05:03:46 PM by Mach1ne »
2007 Parnelli Jones Edition Saleen
302 Stroker
Kooks Long Tube Headers and Cat'ed X-Pipe
342 HP at the Rear Wheels
Offline silverblueBP
    • My 66 2+2
« Reply #51 on: December, 10, 2009, 05:07:48 PM »
Another thought I just had, are you looking at one piece wheels? There's a ton of stress put on the wheels on a road course and a lot (including me) use one pc wheels (TTD's). You might want to check that out.
-Mark-
CarDomain
Offline Mach1ne
  • Track Monkey
« Reply #52 on: December, 10, 2009, 05:17:17 PM »
The problem is that steel wheels are two piece.  I would have to go with a milled aluminum wheel to get a one piece.  More money.
I guess you did not fly out again this morning with the temp being -19?
« Last Edit: January, 01, 2010, 05:15:57 PM by Mach1ne »
    • My 66 2+2
« Reply #53 on: December, 10, 2009, 06:52:30 PM »
No, changed the flight to Jan.
Offline BobV
  • Cloney
    • My Website
« Reply #54 on: December, 11, 2009, 06:05:05 AM »
Thoughts?
4.75 BS is best, but hard to find, especially in a cheap steelie wheel. I THINK you'll be fine , but it's close enough that I'd find a way to BEG, BORROW, or STEAL Jeremy's wheels for an hour...
IIRC, he's running 245/40/17 on front???
These cars vary enough from car to car that what fits on one may be one size too big on another...  :amaz
1991 Saleen #039
Offline daveSanborn
« Reply #55 on: December, 14, 2009, 05:33:44 AM »
Quote
This is a very good point.  While Dodgestangs chart is helpful..... and input and advice from other members is always welcome.... I've found over the years that there are too many small variables to positively "guarantee" that any aftermarket wheel/tire size (other than stock) will fit w/o issue.
The best way to ascertain whether a certain size will fit or not is to borrow a set and try them.
Offline johnpro
« Reply #56 on: December, 14, 2009, 10:21:31 PM »
15's with 4.5" backspace WILL rub the UCA in front, unless you modify the UCAs or run spacers.
Oh... and Johnpro is running 4.25" backspace with his Cragars. That 1/4" makes all the difference in fit...  :craz
My bad.  You are correct.  I checked and I have the 4.25" backspace on 15x8 Crager S/S's
    • My 66 2+2
« Reply #57 on: December, 15, 2009, 05:13:21 AM »
Ok Bob...you're scaring me. Knowing one's backset better than the owner is unsettling  :rp
