Author Topic: Tefba Radiator Filter Install Problem  (Read 2384 times)
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
Re: Tefba Radiator Filter Install Problem
« Reply #25 on: December, 10, 2009, 03:46:58 PM »
Looks like it's still open 2-3" to me, I can see the opposite fender top and a brick wall in the background but that is a good idea about setting the camera on time - closing the hood and letting it take to check clearance. I may use that to check air cleaner clearance when my motor goes back in.
Jon
Yeah, you're right.  Mike's hood isn't closed all the way.
If you wanna check clearance, you can use some playdoh, silly puddy or any non-stick clay.  Just take a chunk and place it on the spot you wanna check; close the hood; open hood; and you have the distance between the object your checking and the hood.
Mike
Offline KBMWRS
  • I need a drink
  • Think before you hate
« Reply #26 on: December, 11, 2009, 07:31:22 AM »
Mike,
How in the heck did you snap this shot with the hood closed?!
I may have a long hose, but you sure have long arms!
Of course the hood isn't closed. I tried to show where the underhood pieces would align with the Tefba cap. From this you can see how far back to set the Tefba.
Offline 68EFIvert
« Reply #27 on: December, 11, 2009, 03:46:42 PM »
Tefba filters look like a great idea.  Too bad they are so damn ugly.  You would think they could make one that is purdy.  Where do you get one from?  Anyone have an extra laying around?
Darreld
Offline KBMWRS
  • I need a drink
Offline MarkStang
  • Rubber Turnin' Virgin
  • Active Poster
  • Spindle Nutzo
« Reply #29 on: December, 14, 2009, 09:16:05 AM »
This is what I did with a custom tube Modification
Love your children
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #30 on: December, 14, 2009, 05:48:27 PM »
so I guess I shouldn't be using swamp water in my system...
I have NEVER had a filter on the coolant. This is in fact the first I've heard of it. Besides getting some crud out, whats the benifit?
Online lethal289
  • Steel Hoods Rule!
« Reply #31 on: December, 14, 2009, 06:16:22 PM »
Whats the benefit of making your pictures small?  Just seems like a pain in the arse to me!
Offline crustycurmudgeon
  • Mr. California Black Plate
« Reply #32 on: December, 14, 2009, 06:26:21 PM »
You can click on them to make them bigger.
Frank
Offline MarkStang
  • Active Poster
  • Spindle Nutzo
« Reply #33 on: December, 14, 2009, 06:37:34 PM »
The crud will wear down the water pump. The crud can get caught in the thermostat and cause the new car engine (new because the old engine over heated) to over heat. The Crud will fill and clog that new radiator, causing the new engine (new because the old engine over heated) to over heat.
My whole adventure started from an over heated engine from an expansion plug a PO put in fell out. So for me , after spending so much money on all these new parts it just made sense to spend a little more to filter out what might be in the new engine. It was "A LOT" at first, chunks of metal shavings, silicone, sand and other unknown junk.
I never had one before or ever heard of one. But I have replaced radiators that were clogged. I have taken out thermostats with silicone caught in them. It is made for people that want to filter out the cooling system. I think you could use a piece of panty hose to do the same thing but it would be a mess to change.
Offline MarkStang
  • Active Poster
  • Spindle Nutzo
« Reply #34 on: December, 14, 2009, 06:40:43 PM »
Because on the dark side you had to make them smaller and I have a lot of articles already composed over there. It is way easier for me to just copy what I already have than to re configure the pics.
Online Fast68back
« Reply #35 on: December, 14, 2009, 07:18:59 PM »
Pssst, Mark, This IS the dark side...
Online lethal289
  • Steel Hoods Rule!
« Reply #36 on: December, 14, 2009, 07:22:55 PM »
Online Fast68back
« Reply #37 on: December, 14, 2009, 07:31:20 PM »
If it was obvious he wouldnt have posted it Mr Wizard....
Online lethal289
  • Steel Hoods Rule!
« Reply #38 on: December, 14, 2009, 07:51:19 PM »
:lol :lol
« Last Edit: December, 14, 2009, 08:04:53 PM by lethal289 »
Online lethal289
  • Steel Hoods Rule!
« Reply #39 on: December, 14, 2009, 07:52:37 PM »
:rofl :rofl :rofl, i just found these and have been dying for a place to post them.  Thanks rick!  :rofl :rofl :rofl!
Online Fast68back
« Reply #40 on: December, 14, 2009, 08:12:16 PM »
Thats because i'm on the webcam with Misses lethal289, I only type on here...
Offline MarkStang
  • Active Poster
  • Spindle Nutzo
« Reply #42 on: December, 15, 2009, 02:08:21 AM »
My stomach....My Stomach
errrr...yeah you know what I meant...gulp.  :craz  :shy :shy :cry :cry :cry :cry
