Author Topic: Tefba Radiator Filter Install Problem  (Read 2384 times)
Offline bluestang
  • Quiet Type
« on: December, 05, 2009, 11:06:52 AM »
Looks like my long awaited Tefba installation will NOT happen :cry Have a 68 Mustang with the 24" radiator AND hood mounted turnsignal lites. It'a a dead on collision! Anyone else with a similar 67/8 and same prob??
Offline johnpro
Re: Tefba Radiator Filter Install Problem
« Reply #1 on: December, 05, 2009, 11:51:45 AM »
We're using a Gano filter on my daughter's '67 with turn signal hood.  No problems with it, at all.
Offline SAC69
  • Yak, Yak, Yak
« Reply #2 on: December, 05, 2009, 11:55:00 AM »
Are you saying the Tebfa top hits the signal lamp assy?   It's that tight at the area where the rad hose attaches at the rad?
Tom
a.m.d.g.
Go Navy!
Offline gtscode
« Reply #3 on: December, 05, 2009, 12:05:17 PM »
I have the same problem. I am hoping I can move the filter back a little closer to the engine. What engine do you have?  This is of course with my 390.
Offline B67FSTB
  • President, StangFix Belgium
« Reply #4 on: December, 05, 2009, 01:05:04 PM »
Why use a filter in the cooling circuit? First i use some kind of an cooling circuit cleaner and flush the system a couple of times.Afterwards i use a good antifreeze and that prevents that the engine is coroding on the inside.
Or do i miss something?
Bruno
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
« Reply #5 on: December, 05, 2009, 02:51:38 PM »
I routed upper radiator hose my a bit differently to accommodate my Tefba filter, and this approach may work for you, too.
Here's a pic.
Mike
Online 70 StangMan
« Reply #6 on: December, 05, 2009, 03:04:23 PM »
You would not believe the crap that the Tefba filter catches. Check it every 6 months or so and there is always something to clean off the screen.
-Dale-
1970 Grabber, 351 W.
Offline garner67
« Reply #7 on: December, 05, 2009, 03:30:56 PM »
+1
On my new engine block build, you wouldn't believe the crud the Tefba filter picks up.  I think it's particularly bad with a new build, due to all the new gasket sealer, and I checked it every week at first.
These days after about 2500 miles, I check it monthly and there's always something to clean off the screen.  IMHO, after spending too much money on my Griffin radiator, a radiator filter is well worth the extra expense and hassle to install.
Offline KBMWRS
  • I need a drink
  • Think before you hate
« Reply #8 on: December, 05, 2009, 04:08:13 PM »
Try explaining your problem rather than just saying it doesn't work.
I have my tefba in line as the normal hose routing goes, with hood signals. No problem.
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #9 on: December, 05, 2009, 05:04:47 PM »
Bruno,
As other's have already said, either when you install an engine that you know nothing about or more importantly installing a newly built block, you need to install a filter for the amount of crud that will come from the engine is unreal.  Eventually it will reduce down to nothing, but until then......
When I first installed a Tefba onto Red, I could not believe how much crap the filter caught, but now there is very little if any so I'm finally considering removing the filter.
Shag has one waiting to be installed.
I hope I don't have any install issues but I'm still a ways away from that point.
Offline crustycurmudgeon
  • Mr. California Black Plate
« Reply #10 on: December, 05, 2009, 07:15:34 PM »
I just looked at mine, and it does look very close.  I believe mine may be touching the t/s light but it doesn't seem to be a problem.  I know they want you to mount the filter horizontal, but perhaps you could mount it on the angled portion of the hose.  It's not too much of an angle.  This is assuming you have a 289/302.
Your other option is to go with the Gano filter, which adds nothing to the diameter of the hose.
Frank
Offline bluestang
  • Quiet Type
« Reply #11 on: December, 05, 2009, 08:22:51 PM »
Have a small block (5.0) with 68 hoses, etc. 24" rad, same size,etc. as 390, I believe. Looking furthur, figure I can trim hose at gooseneck about 3/4". Have an extra 68 upper hose which will give a bit more room from the rad. Also, looking at TS lite housing, a small amount can be shaved.
As it is, it hits dead on with the hose. Maybe KBMWRS could post a pic-appreciate it.
Offline B67FSTB
« Reply #12 on: December, 06, 2009, 12:14:13 AM »
+1
You have a point there.
But probably you guys in sunny california have more cooling problems then we have in  Europe because outside temperatures is not that high overhere.
I noticed that severel people living in warm countries or states ain't using any antifreeze in the cooling system of their car.So , cast iron motorblocks tends to rust inside.
Offline cmayna
  • DILLIGARA ?
« Reply #13 on: December, 06, 2009, 07:04:06 AM »
Bruno,
On the contrary, of my fellow Calif Mustanger friends are running very little coolant (20% coolant, 80% distilled water & a bottle of water wetter) and we are not encountering rusting insides.   This forumula keeps our beauty's running cool in the sunny California weather.
I believe these filter are best used as I said earlier, when you install a new motor and you want all that building junk to not get into the radiator.
Fitment-Yes the Gano is actually smaller in diameter than one's upper hose.  The only thing I don't like about them is you cannot easily open and clean them like you can with the Tefba.
I think moving the Tefba closer to the radiator might help this particular issue.  Sounds like a trial and fit project.
Offline KBMWRS
  • I need a drink
« Reply #14 on: December, 07, 2009, 08:13:14 AM »
I'll take a pic tonight and post on Tuesday.
Offline KBMWRS
  • I need a drink
« Reply #15 on: December, 09, 2009, 07:36:49 AM »
'67___390____Griffin Rad
Offline bluestang
  • Quiet Type
« Reply #16 on: December, 09, 2009, 12:32:22 PM »
Thanks for  posting pics. Looks GOOD!
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #17 on: December, 09, 2009, 03:22:39 PM »
If there is a problem of clearing the hood light inserts, can't you move the filter back towards the thermostat and gain some clearance?
On the other hand, you could simply rotate the filter 90*...just thinking outside the box!
Panama City, FL
Offline AzPete
  • Classic...less
« Reply #18 on: December, 09, 2009, 05:20:40 PM »
I believe the idea is to have the filter in a position where it can be opened, cleaned and installed without the coolant flowing out.
USAF/Ret.
7 Previously owned..66-07
Offline Midlife
  • DOM
« Reply #19 on: December, 09, 2009, 05:55:31 PM »
Spoil-sport.
Offline KBMWRS
  • I need a drink
« Reply #20 on: December, 10, 2009, 07:22:02 AM »
That's what Garner did...see his pic/post... a lot of hose....and he brags about that fact. :omg
Offline bluestang
  • Quiet Type
« Reply #21 on: December, 10, 2009, 10:38:50 AM »
Well, I did a "rig" using two upper hoses. It does work, but the tefba is at a 20 degree angle, coming off the inlet on the manifold. I would have to let water out of rad to clean it. Looking at KBMRWS' pics, see the difference with the 390 upper hose. It is hooked up for now but am going to change it. I know that there is crud in the system so want Teffboy to do it's job.
Offline garner67
« Reply #22 on: December, 10, 2009, 12:07:55 PM »
Mike,
How in the heck did you snap this shot with the hood closed?!
I may have a long hose, but you sure have long arms!
Offline 68EFIvert
« Reply #23 on: December, 10, 2009, 12:27:06 PM »
I would guess time delay and camera on battery.  Cool pic though.
Darreld
Offline Jonk67
  • Yak, Yak, Yak
  • Smyrna, TN
« Reply #24 on: December, 10, 2009, 01:08:56 PM »
Looks like it's still open 2-3" to me, I can see the opposite fender top and a brick wall in the background but that is a good idea about setting the camera on time - closing the hood and letting it take to check clearance. I may use that to check air cleaner clearance when my motor goes back in.
Jon
