Author Topic: Anyone know how to make Dynamite sticks?  (Read 7867 times)
Offline shaggycowboy09
  • NewB
Re: Anyone know how to make Dynamite sticks?
« Reply #125 on: April, 12, 2011, 08:53:29 PM »
wow that's a lot to take in..I'm using incandescent bulbs for my setup, and I'm gonna need to get 2 more dual filament bulbs and sockets for my tail light assembly (also using a dremel to make the sockets lock in place).  This is for a 1995 Acura Integra 2dr but am also makin a set for my buddy's '06 GT, I know you are prolly thinking, "why are you on this website" but I also like muscle cars/trucks.  I use to own an '88 short-wheel base f150 but the high gas prices switched me to imports (gets expensive goin to college back and forth).  But anyways, if you are still willing to help me out then I'll give you some more info on my car.  So my three bulbs going from inside to outer should have a brake/turn signal going into one filament in each bulb and a running light wire into the other filament and of course a ground wire?  Bulb one works off the normal turn switch while bulbs 2 and 3 get there juice from the outputs of the module in proper sequence?  Is my setup gonna be difficult to wire up like a cobra's sequential tails cause I've been searching online to find that the cobra is a different wire harness setup than GTs and v6, or havin to do with the amber lens?  I'm also not quite sure on what you mean by your last paragraph, talkin bout separate battery power sending brake/turn signal, tied together with diodes..  Could you elaborate a lil more on that subject since I won't be using LEDs? At least not yet..  And I'd like to see a vid of your tail lights sequencing cause I'm sure the red is super bright..good job on that by the way
« Last Edit: April, 14, 2011, 08:12:35 AM by shaggycowboy09 »
  • NewB
« Reply #126 on: April, 14, 2011, 07:50:05 PM »
Is this the type of circuit I would have to make to connect the brake signal with the turn signal on one bulb filament?
http://www.mg-tabc.org/techn-up/turn_signal_relay/turnsignalrelay.html
Offline apollard
« Reply #127 on: April, 14, 2011, 08:13:20 PM »
That is an ingeniuos way of handling the issue, and would work well. One thing to watch for is that you are not overloading the wiring - 3 1157 brake light bulbs will pull around seven amps when all are lit.
  • NewB
« Reply #128 on: April, 14, 2011, 08:32:44 PM »
yeah it took me forever to find that page bout those DPDT relays.  So I should get (2) 10amp DPDT relays to do this mod to handle the ~7amp load?  Also I got a replacement flasher relay today that way I could modify it to be able to sequence all three lights, but I opened it up to find only a black box with other TINY timers and what-not..Also, it had one capacitor..I don't believe I would be able to change any resistors in this flasher hence there are none visible.  I'm prolly just gonna get another 3 prong flasher relay that FORD makes (with correct B L E positions) and modify that one.  I also purchased some FORD dual filament sockets and 3157 bulbs at autozone today..thanks again for all your help!
Offline One_fast67
  • Quiet Type
  • Pool Boy
« Reply #129 on: May, 14, 2011, 12:32:31 PM »
Apollard - what were the specs on the LEDs you used to make your arrays?  Do you recall manufacturer and part number?  Is it true that you want to get LEDs with the greatest view angle as possible with the highest millicandela rating possible?
Also, what material did you mount your LEDs to?
« Last Edit: May, 14, 2011, 12:41:09 PM by One_fast67 »
Brad
Gripping the wheel, his knuckles went white with desire.  The wheels of his Mustang exploding on the highway like a slug from a .45. True death: 400 hp of maximum performance piercing the night.  This is Black Sunshine. - White Zombie
Offline apollard
« Reply #130 on: May, 20, 2011, 05:53:56 AM »
Gonna post replies to some PMs & emails here, so the info is available for others in the future:
I used Cree  LC503UHR1-15P. Do a Google search on that and it will pull up a datasheet. Nothing magical about it, I picked it because of the mounting, the intensity, color (you need to use the same color as the lens), and it was cheap from Newark at the time.  It looks like it might not be available anymore, but this one might work. It has less intensity, but the viewing angle is 2x as wide – the actual light output is probably about the same. So, it might even work better. http://www.newark.com/cree/lc503uhr1-30p-a-00001/led-red-5100mcd-624nm/dp/02P7159
And, it’s cheap right now. Buy extras, as the failure rate for LEDs is ~1%, and you’ll fry a few. If they make it past the first 10 hours, they are good for a long time. But, some may die.
I used PVC to mount the arrays. I cut PVC pipe to width, split it, and heated to flatten. I then heated it and pressed it against the lens to get the general shape of the lens. By forming it into the lens profile, I got a good fit in the light assembly, and just needed some weatherstrip to pad it  - with the w/s in place, it stays where I want it after assembled. I also drilled the holes for the LEDs so that they were pointing directly at the lens. If you drill them perpendicular to the PVC, they will not point correctly and the lens illumination will be uneven. I drilled the holes for a tight press fit.
Here is a rough drawn schematic. I decided my array to get what I thought would be a good even spacing. That turned out to be a 4x6 array (frankly, probably too much, as they are bordering on too bright). You will need to figure out a resistance value for Rx. A good starting place is the LED array wizard http://led.linear1.org/led.wiz . LEDs are very voltage sensitive, so design for the car running voltage (mine is 14.4v, but I run a 3G alt). Also, I did not calculate the array using the max mA the LEDs could handle – this extends the life, as running them right at max current is bright, but will stress them. The wizard will give you a good idea what the starting point is, but I did not use the wiring they show there but only one resistor per array (to allow the park light tie-in).[1] So, I had to adjust my values to get them to the brightness I wanted in the car (most likely would have anyway, as the blocking diodes cause some voltage drop). Ry for me turned out to be ~10 times Rx. Again, start there and adjust as needed. I can’t remember what values mine turned out to be.  The blocking diodes shown are 1N400x types, I used 1N4004 IIRC.
 1. note that you could wire the array as the wizard shows, and then the parking light resistor would be an additional drop. In my development, I started out as shown in the schematic, so that's how I stayed.
« Last Edit: May, 20, 2011, 05:56:06 AM by apollard »
