After hearing you guys about the finish I put on a coat of paint. Here are the pictures of my old pan next to the canton. The Ebay pan is almost 2" taller. The new one should work much better!
Here is the dipstick tube with a fitting attached for my blower return.
Check out the difference in baffling.
The difference in height is actually a little more than this. The canton pan tilts weight to the back and lifts the top.
xxxx
