Linux Mint 11 Rulez....
Warning of possible stupid question but to do the TrickFlow pan do you need to change anything other than the pan? Does a stock dip stick work, etc?
Summit is where Jeremy's and my daughter's Trickflows came from. Go fer it.
Ya know, while your at it, an aluminum driveshaft would help the performance.... Just sayin..
Shift kits are the bomb.
I wouldn't have the first clue how to install one.
I've considered one...they don't appear to be that expensive. The problem is I wouldn't have the first clue how to install one.
No... mine came from the Tranny Pan Fairy. :po
Thats because you need to forget about the shift kit, and just get a performance valve body with the kit installed. Then just swap them out.
Yes, that is the exact valve body i have in my C4. Although i couldnt help you on the install. I gave it to the trans shop while they were rebuilding my C4. :craz
But the trans shifts great by itself with no problems in drive. You are correct in thinking that a full manual would need shifted all the time between gears. This valve body is not full manual. Hope that helps.
