I made 2 mounting plates about 3" x 14" that run vertically on each side of the radiator.Each plate bolts directly to the left & right side radiator flanges. Then the plates bolt directly to the radiator support sheet metal. I was able to use a couple of existing holes on the radiator support, but I did have to drill 2 new holes in the radiator support sheetmetal to line up to the mounting plate.Lastly, even though the mounting plates bolted to the sides of the radiator firmly secure the radiator in place, I also glued a 1/4" thick rubber pad to the strut rod supports as a little extra piece of mind. The last thing I want to do is replace that costly Griffin radiator!!!Let me know if you don't understand what I've done, and I can try to take a few pics this weekend to help illustrate what I did.
This is my first question: The radiator doesn't fit into the little bracket here, so do I just widen it and make it fit? and bolt it in?(there's such a large hole in the little bracket for attaching, why did they make the mounting hole so large.
