Looks very nice. Be very careful not to let anything touch those fins. You wont believe how easy they can become distorted. Ask me how i know.
To keep the top of the radiator clean, I fabricated my own plate mounts using the radiator flange mounting holes. The plate bolt to the radiator flange, and the plate bolts to the radiator support, which had to be drilled to accommodate the mount holes.Here's a picture from the top...
Yes lethal~ I'm very careful with it! Your motor is so darned Fine! (or sick in todays terminology?) I was thinking about cutting some cardboard to cover the fins, come to think of it, I'll do that tomorrow! Thanks for pointing that out!dne'
This is my first question: The radiator doesn't fit into the little bracket here, so do I just widen it and make it fit? and bolt it in?(there's such a large hole in the little bracket for attaching, why did they make the mounting hole so large.
Wow, I'm shocked the lower brackets do not get mounted to anything
Thank you for the compliment! BTW, where did you get the neat adjuster for your alternator? That looks much better than trying to adjust the belt tension with a large scewdriver!
This is something that has always make me a little aggravated since the beginning of buying parts from a Mustang store. Like these clips, surely the seller knows a person will need these clips, and that goes for so many things and it has cost a great deal of frustation and time to get the little nut that goes with it(whatever) and the seller should know this, or at least ask! ("hey, by the way, you may want to buy the nuts that go with this upper radiator bracket!") lol I'm almost done now, but I still haven't learned to ask! lol so it's my fault! :cry
Its the March Performance Bracket and pulley Kit. Heres some other pics since you mentioned it, it really does make it easy to adjust but fitting hoses on the power steering can be a real deal breaker.
garner67, thank you for posting the photo~ could you explain this installation a little more in detail? I like the way that looks~ I was looking at how I could use the holes in the new radiator eventhough they didn't match up to the radiator support.dne'
