Linux Mint 11 Rulez....
So, my local parts store will have them...?
It still amazes me
Or would my increased RPMs not be a factor?
Now, a Ford power steering pump that was used on numerous vehicle models for 25 years? They'll have 2-3 on the shelf and can't keep them in stock as they continually fail/go bad/always need replacing.
You mean like when I was 17 and had to put two or three master cylinders in my old '82 F150 before I got one that didn't crap out almost right away due to buying remanufactured parts?
Exactly.... A cheaply made part to begin with that when rebuilt is even more likely to fail will always be in stock!
It appears to be weaping from behind the large nut that tightens up against the rear of the pump housing.
And you're saying there should be a seal behind that nut Dave?
