Author Topic: New Instrumentation for Shag  (Read 1682 times)
Offline pnandy
Re: New Instrumentation for Shag
« Reply #25 on: October, 15, 2009, 03:05:27 PM »
cool i bought the gauge a long time ago but never bothered to try it out. i install it win i wire up the stock tach
Patrick
Offline Fast68back
« Reply #26 on: October, 15, 2009, 04:50:33 PM »
Read Craigs entire thread, he didnt just stick it in there like your thinking. It would take some modification to use an aftermarket gauge with a stock cluster.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #27 on: October, 15, 2009, 08:00:41 PM »
hey was it hard to put the oil pressure gauge in clock delete spot? what was involved
If you are asking about mine it wasn't too bad. I had the standard non-tach cluster. When I put in the 67 Cougar Tach I gave up the oil pressure and amp gauges. The 68 cluster had the oil pressure swapped with the 67 fuel gauge so I used a 68 oil pressure gauge.
67 Cougar "doner" cluster
The Cougar cluster wasn't as deep as the Stang so I had to cut the "cup" and weld in a 1/4" strip to make it deeper.
I then took all the gauges apart and painted them semi gloss white
then put the overlays on and painted the needles fluorescent orange with model paint
The oil pressure gauge mounted with a bracket I fabbed up that looks like the aftermarket gauge brackets, it needs to be insulated good or you will fry the instrument voltage regulator (ask me how I know this). I just plugged the original wire from the oil pressure gauge right into the 68 gauge. The lens is a modified lens from the temp or fuel gauges cuz the clock lens has a hole in it for setting the time.
I changed the bulb covers from blue-green to red-orange
Not as nice as what these other guys have but it works.
Sorry to hijack the thread Craig!
« Last Edit: October, 15, 2009, 08:08:46 PM by tarafied1 »
Offline Fast68back
« Reply #28 on: October, 15, 2009, 08:17:01 PM »
I always wondered why you had two speedometers...
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #29 on: October, 15, 2009, 08:50:32 PM »
 :rofl
Offline lethal289
  • Steel Hoods Rule!
« Reply #30 on: October, 16, 2009, 05:47:35 AM »
Awesome work Craig.  You have some serious skills.
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #31 on: October, 16, 2009, 05:48:50 AM »
That's what my wife tells me.... :naug
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #32 on: October, 16, 2009, 08:43:58 AM »
Thanks Lethal, Craigs' do good work!
Offline lethal289
  • Steel Hoods Rule!
« Reply #33 on: October, 16, 2009, 10:52:49 AM »
:rofl
Offline cmayna
  • DILLIGARA ?
« Reply #34 on: October, 19, 2009, 06:09:46 AM »
Test fit of dash trim and bezel.
Offline daveSanborn
« Reply #35 on: October, 19, 2009, 06:46:24 AM »
Assembly is a LOT easier w/o the dash pad in place.....
Offline lethal289
  • Steel Hoods Rule!
« Reply #36 on: October, 19, 2009, 02:34:19 PM »
And without a window and seats....  Plenty of room to work.
Offline silverblueBP
    • My 66 2+2
« Reply #37 on: October, 19, 2009, 07:15:14 PM »
Looks great Craig, I like the "cornholeo" touch.
-Mark-
CarDomain
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« Reply #38 on: October, 21, 2009, 09:08:08 AM »
I do believe it's "Cornholio"
    • My 66 2+2
« Reply #39 on: October, 21, 2009, 09:25:26 AM »
Whatever, Duane Jr.  :bird
Offline 70_Fastback
« Reply #40 on: October, 21, 2009, 09:28:24 AM »
 :bow
And back to Craig's dash.  I think it looks great.  Good job Craig.
Offline Gi-Ti-Up
  • NewB
« Reply #41 on: October, 28, 2009, 10:32:15 PM »
WOW!  That is sharp!! Big Cheers, Bill Palmer
Offline B67FSTB
  • President, StangFix Belgium
« Reply #42 on: November, 09, 2009, 02:47:54 AM »
Damm Craig , that looks very sharp !  Shag deserves this surely !
I was looking also to do this but i wanted a Km/h speedometer and autometer has in the 5" serie only the ultra lite serie .So far so good .But....  the water temp and oil pressure gauges in that serie are all mechanical in the metric version.That means i have some tubing to my cluster and is something i don't want !!!  You are so lucky.BTW  backingpanel did you make this on your own or did you buy it...and where..?
Bruno
Offline cmayna
  • DILLIGARA ?
« Reply #43 on: November, 09, 2009, 08:55:06 AM »
Bruno,
Bought the backing plate from Mustangs Unlimited.  It was a pretty cheap looking piece of plastic that I could have probably built myself.
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #44 on: May, 11, 2010, 04:04:35 PM »
Craig, any chance you still have those pics to re-post?
Sam
Member number 427
68 Coupe
