Linux Mint 11 Rulez....
Why?
Spring pressure is good. Unless I can find a problem with a lifter it seems to have been a fluke. Timing was spot on during checks. Went ahead and ordered a new water pump also. Why not...I've already rebuilt the carb.
I'd take that bent valve in and have some metallurgical testing done, could happen to others and then you'd have to go through this again & again.BTW, why'd you rebuild the carb when it obviously didn't need it???
......because he needed a water pump.........
