Author Topic: Carbon fouled plugs  (Read 1198 times)
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
Re: Carbon fouled plugs
« Reply #25 on: September, 30, 2009, 08:40:59 AM »
Thanks for all the help everyone.
Last night I removed and inspected the dist cap (checked out ok, no cracks); inspected all the plug wires (look undamaged); and reinstalled the carb (Recarbco did adjust the idle mixture when they tested the carb).  Everything looked fine, however I did notice that the (+) connection to the electric choke wasn't making a firm connection, so I fixed that.  It was too late to fire up the engine last night (without penalties from "the boss"), so I got up this morning and cranked it up.  It seemed to be running smoother when I revved the engine, but I didn't have time to move cars around to give it a test drive.
Unfortunately, I have plans tonight, so I won't be able to touch the car again until Thurs.  Hopefully, it's running better again.
Thanks again.
Mike
Offline daveSanborn
« Reply #26 on: September, 30, 2009, 09:19:59 AM »
Quote
Sure, no problem.  That's what internet solitaire is for.  I figure Thursday should give me plenty of time to play a few hundred games......
Offline garner67
« Reply #27 on: September, 30, 2009, 12:36:29 PM »
Ok, I couldn't stand the waiting, so I told work that I had a lunch time doctor's appointment, and I went home to fire up the ride.
drum roll...
Success!!!
I guess between the adjustments Recarbco did for free on their test engine & flow bench and the repaired lose choke connection, my engine stumbling issues have been solved.  However, I'd like to purchase a wide band fuel meter some day soon to really see how that carb is performing on my engine.
Of course, with one success comes another challenge.   After taking the quick 3 block spin, I pulled back into the garage to discover the lower radiator hose leaking.  Oh well, that's a simple fix I'll do this weekend.
Thanks again for the support.  :tigg
Offline silverblueBP
    • My 66 2+2
« Reply #28 on: September, 30, 2009, 06:15:01 PM »
Glad it was a relatively easy fix!
-Mark-
CarDomain
Offline monkeystash
« Reply #29 on: October, 02, 2009, 08:04:07 AM »
Glad you figured it out Mike.  I'll bet you a dollar the choke wasn't open before, causing the rich mixture.  If it happens again, wire the choke open to eliminate that variable.
-Ryan
