Let me know if it's a problem for you.
oh bummer! That is a deflector that is supposed to be behind the drain hole so gas can't splash back thru the 1/8 inch hole. I'm glad it didn't fall off before you installed it. I usually check those with the pliers to make sure it's solid. Let me know if it's a problem for you.I will be doing tighter quality control on those for sure!Thanks for letting me know about it. I'm sorry.
After a few warm days, I started to notice a gas smell in my car. I thought it was perhaps just fuel from the carb after shutdown. I checked all over for any signs of a fuel leak. None found. The last place to look was the modified fuel filler neck. I turned off my garage lights, and used a strong flash light. I stared down the fuel neck, while lighting up the fuel neck inside the trunk. I saw a small light leak into the filler. I found my leak. The welded in plate had a small burn thru was allowing fuel vapors to fill my trunk as the temperatures fluctuated. I put some tape over the area until I am able to get it fixed (rewelded?). I guess this is just a heads up. Fuel vapors can be a very bad thing. Unless the tank is full, the cooling/heating cycles can pump out significant fuel vapor volumes.Henry
sorry 'bout that dude! I have begun testing with a gas cap and filling it with water. I will try the closet and light thing, sounds better.
Grown men using flashlights to inspect their parts in closets.
