Well, you had a 50/50 shot.... the larger valve is the intake valve.
If possible, compare the exhaust ports (where the exhaust manifold/header bolts on) on the 4V heads with those of any aftermarket small block cylinder heads.
Notice that the exhaust ports are likely 50% larger than any other head.
