Eddy 1406.
Duane, Heck, if a dumb HS kid can rebuild an old 4V, you should have no problems...
I'll get a pic if time permits.
Your obviously not going anywhere..... :nice
R & R'ed the carb. No dice. During one of the stalls I popped the air cleaner off and hit the throttle. No gas came out of the pump jets at the front of the carb. Hit it again and some came out. Don't know if that's indicative of vapor locking or not. I'm sure someone will chime in. If so I guess I'll re-route the fuel line. I've got an extra set of hands coming over Friday so I imagine I've said "screw it" till then. Filter is still hot enough to where you can only hold onto it for about 5 seconds. If it is locking, why now when nothing has really changed?
"Chiming in......." If there was no gas at the carb on the first pump, it could very well be vapor locking.
If it is locking why did it just decide to start? Nothing was changed when it first happened.
That is how a vapor lock works. There is no mechanical lock of anything. The fuel in the line and fuel pump gets hot and vaporizes. This causes the fuel to stop flowing as the vapor "locks" the line/pump. As things cool, the vapor disappears and you now have fuel movement. Time can vary based on many things. An electric fuel pump can eliminate this.
