Author Topic: New ORP double roller spring perches  (Read 2606 times)
Offline AzPete
  • Classic...less
Re: New ORP double roller spring perches
« Reply #50 on: August, 06, 2009, 07:50:01 AM »
Just curious, that control arm does not look like it came from a car that was being driven currently.....maybe from one that has been parked for some time. There is pretty old looking corrosion around the perch rubber itself.
USAF/Ret.
7 Previously owned..66-07
Offline Opentracker
  • Opentracker Racing Products
« Reply #51 on: August, 06, 2009, 07:50:49 AM »
If you put a new rubber bushing perch in the BFing vise and try and pivot it with a 3' pry bar, you'll end up lifting yourself off the ground before you spin the perch.
Offline Opentracker
« Reply #52 on: August, 06, 2009, 07:53:57 AM »
Check out the clean threads on the shaft kit. These arms were on the road just before the photo. They came off our 66 coup.
Edit - Yes .... Cars do rust in California
Offline silverblueBP
    • My 66 2+2
« Reply #53 on: August, 06, 2009, 07:57:41 AM »
John....question about your avatar pic; is that at the top of the corkscrew and if so, was the car outta shape? The line looks really weird!
-Mark-
CarDomain
Offline Opentracker
« Reply #54 on: August, 06, 2009, 08:07:26 AM »
It is Laguna and no, the car is on line. It does look a little odd I admit from the angle the photo was taken.
I have around 10K laps around Laguna and do driving instruction there for the Shelby Club. I was a track crew member there for 5 years too.
I rode down the cork screw on a office chair one day. Got going way too fast and had to bail. The track drops 30 feet from the top of 8a to 8b. I have a ton of stories about that turn.
    • My 66 2+2
« Reply #55 on: August, 06, 2009, 08:20:18 AM »
I'd love to drive Laguna :toot :toot
<thread hijack now complete>
Offline Opentracker
« Reply #56 on: August, 06, 2009, 08:26:15 AM »
My buddy Dave a little out of shape.
Propper line
Offline Starfury
  • My car HATES me
« Reply #57 on: August, 06, 2009, 09:06:00 AM »
The rubber bushing spring perches have been known to rip the bottom off the shock. Lot's of bind there.
That happened to me!  I KNEW I wasn't the only one!
I had been running newer (1yr old) standard perches, almost brand spankin new Edelbrock shocks (which are upside down, so the weak point is at the perch), and stock springs.  I was out running around back roads with the local car club when I cam over a rise too fast and came down hard.  Heard a loud CLANG, which was repeated in miniature every time I went over a bump on the way back.  Upon inspection I discovered that the left shock piston rod snapped clean off at the lower mount that bolts into the perch.  I was not happy, but at least it gave me a good reason to switch to roller perches.
Tad H.
'67 fastback
331 stroker
3sp m/t
