Author Topic: Monte Carlo Bar or TCP Brace  (Read 1558 times)
Offline Fast68back
Re: Monte Carlo Bar or TCP Brace
« Reply #25 on: January, 27, 2010, 08:59:40 AM »
Do you have an export brace installed?
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #26 on: January, 27, 2010, 09:01:54 AM »
Yes, still have the 2-piece original. Do I to remove it to spread the towers?
'68 F250 Crew Cab 4x4
Offline Fast68back
« Reply #27 on: January, 27, 2010, 09:08:13 AM »
I would remove the export brace and jack the car up by the lower radiator support crossmember.
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #28 on: January, 27, 2010, 09:11:33 AM »
If I did that, I'd be scared the export brace will be misaligned.
Offline Fast68back
Offline buening
« Reply #30 on: January, 27, 2010, 09:23:09 AM »
That would be 42.25 - 41.50 = 0.75"
Interesting, that's exactly how far mine is off.  I wonder if these Monte Carlo bars are 3/4" too long?  Can anyone else confirm their length that has one already installed that DIDN'T need to jack their shock towers apart?  My 1 piece export brace fits with a little pursuation of the bolts, so jacking the towers apart 3/4" will screw with the fit of the export brace.  This is exactly why I haven't installed mine yet!
Custom Motor Mounts
T56 Conversion
Offline silverblueBP
    • My 66 2+2
« Reply #31 on: January, 27, 2010, 09:26:53 AM »
Just went and measured mine, std straight bar;
40 1/4" from fender to fender right in front of the bar.
-Mark-
CarDomain
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #32 on: January, 27, 2010, 09:33:55 AM »
Nope, I'm pretty sure these towers cave in slightly even with an export brace.
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #33 on: January, 27, 2010, 09:41:15 PM »
I was using a bottle jack and a 2x4 to spread the towers w/out success... it kept slipping. So, now it's either a portable hydraulic ram rental or buying one of these...
http://www.amazon.com/JackMate%C2%AE-Lift-Jack-Accessory-Black/dp/B002YPWQQA
Do you think this would work fine?
Offline 68EFIvert
« Reply #34 on: January, 27, 2010, 10:18:50 PM »
I am using the bar from Street or Track but had to make some modifications to clear the blower tube.  It also allowed me to clear the EFI dizzy.
Darreld
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #35 on: January, 28, 2010, 08:50:10 AM »
Scotty at Cobra Auto recommended modifying the Monte Carlo bar to fit... O.75" to 1" is just going to open another "can of worms", I was told. Advice?
Offline daveSanborn
« Reply #36 on: January, 28, 2010, 10:42:11 AM »
Quote
Advice?
If you're positive that your shock towers have shifted that much.... personally I'd want to correct the problem rather than adapt parts to it.
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #37 on: January, 28, 2010, 10:46:20 AM »
To be positive, I could measure the width of the engine bay at the back firewall to compare to the middle.
Offline buening
« Reply #38 on: January, 28, 2010, 11:23:04 AM »
Nice of Scotty to specify what is included in the "can of worms".    Spreading the tower apart will affect your alignment, fitment of the export brace, and the fender and hood alignment/gaps.  That's all that I can think of that would be affected.
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #39 on: January, 28, 2010, 10:58:16 PM »
