Author Topic: Need a pic regarding 67-70 trunk dropoff drain hole  (Read 1601 times)
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« on: August, 12, 2008, 01:37:03 PM »
I had to replace the trunk dropoffs in Shag and forgot to note the drain plug hole.  Anyone (cough Rick) have a pic of what the drain hole looks like with the drain hole plug removed?  On 65-66 their on the bottom of the drop off going through the bottom edge of the quarter panel where as 67-70's have the hole at the bottom of the vertical portion of the drop off, towards the front.
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
Re: Need a pic regarding 67-70 trunk dropoff drain hole
« Reply #1 on: August, 12, 2008, 01:49:29 PM »
Offline cmayna
  • DILLIGARA ?
« Reply #2 on: August, 12, 2008, 02:02:34 PM »
Jeremy,
Edited-God I was asleep last night when looking at you pics.  Yes those are not the holes.  The hole are forward near the tires.
« Last Edit: August, 13, 2008, 05:15:45 AM by cmayna »
Offline Fast68back
« Reply #3 on: August, 12, 2008, 04:51:30 PM »
Posted two pics in the gallery, figure if I had to go out in the hot azz garage and crawl under the car and snap pics, your gonna work for 'em!
Offline cmayna
  • DILLIGARA ?
« Reply #4 on: August, 12, 2008, 05:54:46 PM »
Rick, If you look at  your pics compared to 70_Fastback's you'll see he has two holes each side whereas you have just one.  Are the hole you show are at the bottom of the dropoff?   They seem higher.   Also your holes are round whereas 70_Fastback's are bell shaped. Finally based upon the pics I've seen, I don't see how the seals actually attach to the sheetmetal.  Looks to me that there  is a smaller hole right above the main drain hole.
Offline Fast68back
« Reply #5 on: August, 12, 2008, 06:12:42 PM »
Craig, I e-mailed you the picture, the drain hole is actually behind the S in StangFix.com (shameless plug). I took a picture of the same hole Jeremy did, but thats not the drain. I can snap a closer on of the drain if you need. I looked at Jeremy's pictures and took the same ones and didnt read your whole post........
« Last Edit: March, 17, 2009, 09:23:28 AM by Fast68back »
Offline Fast68back
« Reply #6 on: August, 12, 2008, 06:21:28 PM »
This one is the drain (this is the DS front, near the tire)
« Last Edit: March, 17, 2009, 09:23:55 AM by Fast68back »
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
« Reply #7 on: August, 12, 2008, 06:31:51 PM »
The plug that goes in that hole is rectangular shaped and clips into the top square hole
and has a dome shaped cover over the hole. I'll get a cell phone pic of the plug and upload it.
Offline Fast68back
« Reply #8 on: August, 12, 2008, 06:33:04 PM »
I got the plugs........somewhere in a pile of parts waitin to go on the car..
Offline Sluggo
    • www.StangFix.com
« Reply #9 on: August, 12, 2008, 06:43:18 PM »
http://www.stangfix.com/forum/gallery/1_12_08_08_7_41_44_0.jpg
http://www.stangfix.com/forum/gallery/1_12_08_08_7_41_44_1.jpg
Offline 70_Fastback
« Reply #10 on: August, 12, 2008, 07:43:01 PM »
So mine's not the drain hole?  Sure looks like it would function as such.  It's the lowest hole in the drop off area - so the sheot will drain through that one for sure ~dk
Offline Mustang Mike
    • My 68 from start to almost finished
« Reply #11 on: August, 12, 2008, 09:50:29 PM »
The age old question when you buy the rubber seal kits, what and where in the hell do these things go. I found out what the hell they were but nobody could tell me where they went. I found out Sunday where they mount. I seen some pics of a concouse restored mustang and saved the pics. Now my question. Why in the hell do they not put the drain valves in the lowest spot where water will sit? When I do mine I will install them as close as I can to the rear wheel.
[attachment deleted by admin]
Mike W.
Offline Sluggo
    • www.StangFix.com
« Reply #12 on: August, 13, 2008, 04:00:50 AM »
My 69 is basically unmolested and only has the plugs in the very front holes.
Offline cmayna
  • DILLIGARA ?
« Reply #13 on: August, 13, 2008, 05:19:24 AM »
I am baffled to see those drain plugs at the very back of the drop offs.  Not correct as far as I know.
Offline Fast68back
« Reply #14 on: August, 13, 2008, 05:26:36 AM »
I agree, when I looked last night I was thinking there would still be 2 or 3 inches of water in there with the drains located back there.
Offline 70_Fastback
« Reply #15 on: August, 13, 2008, 06:18:48 AM »
Ehem!  So are we saying that mine are not the drain holes?  ~dk
And I'm not even using those drain plugs either.  Minus 1 point for me.
Offline Sluggo
    • www.StangFix.com
« Reply #16 on: August, 13, 2008, 06:42:27 AM »
I'll go look at mine and snap a pic in a little while. It's here at the "J" so next time I head
out in the shop I'll looky.
Offline 70_Fastback
« Reply #17 on: August, 13, 2008, 06:44:40 AM »
What is the "J" ?
Offline Sluggo
    • www.StangFix.com
« Reply #18 on: August, 13, 2008, 07:50:52 AM »
Offline 70_Fastback
« Reply #19 on: August, 13, 2008, 08:11:09 AM »
Oh.  I feel somewhat let down now that I know what the "J" is...
Offline Sluggo
    • www.StangFix.com
« Reply #20 on: August, 13, 2008, 08:34:36 AM »
Sorry ;D
The camera battery took a dump while I was taking pics. I'll try to put them up later.
The hole most rearward is where the harness comes out for the reverse lights.
The front is the drain hole and takes the plugs pictured earlier.
Offline cmayna
  • DILLIGARA ?
« Reply #21 on: August, 13, 2008, 09:51:57 AM »
El Correcto.  65/66's have a similar rearward hole for backup light wiring.
Offline 70_Fastback
« Reply #22 on: August, 13, 2008, 09:55:42 AM »
Ahh... that makes sense.
But mine doesn't have any forward holes in them....
Offline cmayna
  • DILLIGARA ?
« Reply #23 on: August, 13, 2008, 11:01:15 AM »
Put the bong down for just a moment and look more carefully  ;D.  Maybe the trunk dropoffs were replaced?
Offline 70_Fastback
« Reply #24 on: August, 13, 2008, 11:10:26 AM »
Uh, yeah - I replaced all of that rotted out swiss cheese many years ago.  I have pics of the originals - I will go look at those real quick like.  ~thu
