Author Topic: Since everyone here loves 69's...  (Read 886 times)
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
« on: July, 02, 2009, 11:09:11 AM »
It just screams to be grabber orange...
Offline Meyer65
  • Nut Torque'r
  • Active Poster
    • Meyer65's Cardomain
Re: Since everyone here loves 69's...
« Reply #1 on: July, 02, 2009, 11:13:43 AM »
I'd be screaming too if I were a 69 Mustang and someone butchered me like that...
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
« Reply #2 on: July, 02, 2009, 11:28:45 AM »
Is it me or does that hermaphrodite have a 4 inch cowl hood with a cobra jet scoop to boot?
It's gotta be sporting a supra engine.
Online silverblueBP
    • My 66 2+2
« Reply #3 on: July, 02, 2009, 11:34:34 AM »
Oh yeah, that's a great looking 69........in a f'd up homo sort of way. I mean come on, 69's are gay enough to start with, but sheesh  :bash
-Mark-
CarDomain
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #4 on: July, 02, 2009, 11:37:05 AM »
I think you grabbie boys should replace your rear spoilers with one of those.
Offline 70_Fastback
« Reply #5 on: July, 02, 2009, 11:40:09 AM »
An ironing board?
Offline Sluggo
    • www.StangFix.com
« Reply #6 on: July, 02, 2009, 11:40:29 AM »
I think you should replay "unscrew.mp3" again.
Offline KBMWRS
  • I need a drink
  • Think before you hate
« Reply #7 on: July, 02, 2009, 12:12:37 PM »
It needs a bigger scoop...ain't that right? :rofl :rofl :nice
Offline KBMWRS
  • I need a drink
« Reply #8 on: July, 02, 2009, 12:17:13 PM »
So Jeremy how is your car?
Any progress?
Offline 70_Fastback
« Reply #9 on: July, 02, 2009, 12:22:19 PM »
Yeah,  starting reassembly this weekend.  I have all of the parts except for new valves.  Hope to order those today or tomorrow.
Offline daveSanborn
« Reply #10 on: July, 02, 2009, 12:24:59 PM »
Quote
What are you plans once you receive the new valves?
Offline 70_Fastback
« Reply #11 on: July, 02, 2009, 12:40:53 PM »
I took the heads to a local shop near me last night (Cylinder Head Performance).  He took them apart and inspected them.  My plan was to determine the feasibility of going with larger valves.  Upon inspection he recommened that I don't spend more money on stuff that I've already had done.  He would have to put new seats in (which I've already done) and cut the seats for the larger valves & then open the chambers up a bit.  He said I would be in the neighborhood of $500 without valves.
He recommended I just stay with the same size valves except go to an undercut valve to pick of some additional airflow (8 to 9%) and save my money towards a better performance set of heads.
So with that all said, I'm going with his advice.  Oh, and he said I was not running enough spring pressure so he is setting me up with a shim package as well.
I've got a new CompCams timing set:
http://www.summitracing.com/parts/CCA-7138/
Also ordered/received my new HV oil pump & shaft, new FP performance gasket rebuild kit,  upgraded to the 1-piece oil pan gasket though.
Also ordered a new set of CompCam Pro Magnum Hyd lifters to replace the others, which were probably contaminated.
All of the bearings in the engine look good, no score marks etc.  And since they only have 300 or so miles on them I'm keeping them.  Crank and cam all look good as well.
So I'm going to put it back to the way it was basically with the exception of a new chain in lieu of gears.
Offline Fast68back
« Reply #12 on: July, 02, 2009, 01:28:06 PM »
So are you going to steal your kids play doh and check the valve clearances?
Offline 70_Fastback
« Reply #13 on: July, 02, 2009, 01:28:57 PM »
No, I'm going to "borrow" it.
Offline KBMWRS
  • I need a drink
« Reply #14 on: July, 02, 2009, 01:33:08 PM »
OH NO!!! Mister Bill!!!!! :mod
Down you go...into the cylinder.
Offline 70_Fastback
« Reply #15 on: July, 02, 2009, 01:35:36 PM »
 :rofl
And just for fun, I did a Google search for "Mr. Bill" and this came up:
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #16 on: July, 02, 2009, 01:54:48 PM »
amazing how this thread went from gay 69's to a purple Sluggo!
Offline 70_Fastback
« Reply #17 on: July, 02, 2009, 01:56:09 PM »
Purple in da rainbow flag represents "gay".  So we are still half-assed on track.
Online silverblueBP
    • My 66 2+2
« Reply #18 on: July, 02, 2009, 01:57:23 PM »
yeah and I'm usually the one that detours a thread  :wtf
Offline 70_Fastback
« Reply #19 on: July, 02, 2009, 02:00:09 PM »
And no pun was intended by inter-mingling the words "gay" & "ass" either.
Offline daveSanborn
« Reply #20 on: July, 02, 2009, 02:37:00 PM »
Is the silly putty Sluggo wearing a grabber orange muscle shirt?
Coincidence?  I think not!
Online silverblueBP
    • My 66 2+2
« Reply #21 on: July, 02, 2009, 04:09:32 PM »
Yeah, sure.
Some things are better left unsaid.
Offline Sluggo
    • www.StangFix.com
« Reply #22 on: July, 02, 2009, 05:26:22 PM »
Have you done any research on SBFs with high volume oil pumps?
Offline lethal289
  • Steel Hoods Rule!
« Reply #23 on: July, 02, 2009, 05:28:55 PM »
I did, and then i decided to go with one too.  So far i have had no problems maintaing a good constant oil pressure with a standard volume pan.
Online silverblueBP
    • My 66 2+2
« Reply #24 on: July, 02, 2009, 05:32:54 PM »
I'm running a HV pump, no problems here in 4 years and my engine spends the majority of its time between 5,000 and 7,000 rpms.
