Linux Mint 11 Rulez....
None of you opinionated SOBs have chimed in yet?Where's the love?
Hey douchebag, why don't you call Dean and talk to him about the heads? He could probably give you any info you want / need.
Did it not run well enough?
Gimme Deans digits - but make sure with him if it's ok that I dumb him down on the phone... :wstup
Interesting. The engine does not see a lot of high rpms. I'm typically 2k to 3600 most of the time.I'm going to have to give this one some more thought.
Assuming that I may have valves damaged & could potentially be yanking the heads off.....
the 268H or 280H is a much better street cam with gobs of torque if you're not winding it out. They still rev to 6K when you want to.
70fastback, if you need to do head work, I'd suggest looking for some GT40's before you put time/money into those J code heads.
I wouldn't assume that the valves are damaged. Why would they be? Your 351 is not a Honda 4 cylinder with an interference fit valvetrain.
I honestly don't know for sure, as never having experienced this yet - but logistically it seems possible, to me, that if a valve was fully open with the cam stopped that a piston could possible ting it a little though...
I still can't fathom that you've not torn into the engine yet.
Having run both, I'm much happier with the 280H (w/Rhoads lifters). It's more happy to wind up to 6k, and I take it there fairly often.70fastback, if you need to do head work, I'd suggest looking for some GT40's before you put time/money into those J code heads.
