Author Topic: 9" Rear Options - '66FB  (Read 2148 times)
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
Re: 9" Rear Options - '66FB
« Reply #50 on: June, 25, 2009, 01:10:34 PM »
that's an auction for a posi differential only. :dumas
i think 9" is in my future.
'68 F250 Crew Cab 4x4
Offline daveSanborn
Offline johnpro
« Reply #52 on: July, 03, 2009, 05:22:37 PM »
Decent springs in the back will be all that's needed with those tires to eliminate wheel hop.  I have no wheel hop at all in my '69 with 15/275/50's in back behind the 408/TKO.  They are also BFG Radial T/A's.  I have no traction, but no wheel hop, either :conf
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #53 on: July, 06, 2009, 09:47:27 AM »
guess you need more tire in the back! i'm thinking of mini-tubbing... read the following and reply:
http://www.stangfix.com/testforum/index.php?topic=2005.0
Offline mrgem
  • NewB
« Reply #54 on: July, 15, 2009, 08:31:25 PM »
Not sure if anyone has suggested it, but this is what I did for my 66 fastback with a 351:
A local rear end shop has a source for 1960s full-sized car (Galaxie, Monterey, T-Bird, etc.) 9 inch housings and pumpkins. They simply cut the axle housings off the big car 9s and grafted the housings from my 8-inch (which was fried by that Windsor) on to the big car center section.
I had them build the center section as a Trac-Lok unit (4-spider) and used my 28-spline axles out of my original 8-incher. The results are very tough to distinguish from an original early Mustang 9-incher. The rear end guy also upgraded my backing plates at the same time to use 2-inch wide 68 and later big block Mustang shoes. Again, you'd have to be an expert to differentiate this setup from a stock HiPo Mustang. And the cost was under $1200.
I also had the option of simply building a beefier 8-incher with a 4-spider setup. I am told this combo yields a rear that is darned near as strong as a 9 -- but many pounds lighter. For whatever reason, I chose to go with the 9 for my fastback. But I'm currently building a 65 Cyclone (331 powered) with a beefed up 8-incher.
1966 GT Fastback -- Reassembled properly (using pieces and parts from a number of donor cars) after several generations of neglectful ownership.  Originally an A-code/Toploader car...But now sporting a 351 Windsor and other subtle modifications.
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #55 on: July, 15, 2009, 08:46:09 PM »
majority of people voted for a 9", so i went with it... 31-spline Moser axles, 3.50 gears, stock length. in the future, i have the option of swapping in more HP.
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #56 on: August, 08, 2009, 04:38:39 AM »
Just got the rear end yesterday. The housing is bare metal. Does it need to be prepped clean before priming? What did you use?
Offline silverblueBP
    • My 66 2+2
« Reply #57 on: August, 08, 2009, 04:50:03 AM »
Grease and wax remover, clean it up with some 400 grit, G&W remover again, prime, paint, install.
-Mark-
CarDomain
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #58 on: August, 08, 2009, 10:45:31 AM »
Cool. I bought mineral spirit, 320 grit paper. I don't need high-heat primer & paint, correct?
    • My 66 2+2
« Reply #59 on: August, 08, 2009, 11:16:35 AM »
I just used Eastwood's chassis black.
Offline lethal289
  • Steel Hoods Rule!
« Reply #60 on: August, 08, 2009, 02:23:18 PM »
what unit did you get and from where?  This may be my winter project!
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #61 on: August, 08, 2009, 02:47:30 PM »
I believe I mentioned it in here...
Offline lethal289
  • Steel Hoods Rule!
« Reply #62 on: August, 08, 2009, 03:03:32 PM »
Theres a lot of talk about looking on ebay, craigs list, etc...  Sorry if its to hard a question to answer again.  My apologies.   :crazy    Besides, I know yours is a 66, mines a 67 blah blah blah....  Now ill just  :stfu
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #63 on: August, 08, 2009, 03:12:59 PM »
Moser 9" housing + 31 spline axles, Moser center section, True-Trac diff w/3.50 gears, stock length.
Offline hivewax
  • EngineeRunner
  • Yak, Yak, Yak
  • Loren Pittack
    • CarDomain
« Reply #64 on: August, 08, 2009, 03:14:17 PM »
All thru Cobra Auto.
    • My 66 2+2
« Reply #65 on: August, 08, 2009, 05:21:20 PM »
First of all  :yikes, you musta won the lottery!
Second, you are gonna LOVE the locker  :tigg
