Follow up to my alternator issue.I installed a brand new 100-A alternator and a new Borg-Warner voltage regulator (read $40!) last night. Adjusted everything, plugged everything back in. Fired it up. And it's not charging. The BAT post on the alt reads the same voltage as the battery. The two readings should match, but I suspect what you meant is that it is reading 12.5V or so.If I unplug the 4 prong plug from the voltage regulator and jumper the "A" & "F" terminals it charges like it should 14.x volts.Good!I tried the other new voltage regulator that was on there and it does the same thing. I'm at a bit of a loss here.Sluggo mentioned on the phone last night that there could be an issue because my original gauge cluster had an amp meter on it and I converted to all new autometer gauges and installed a voltmeter. So the printed circuit plug is not connected to anything and maybe a circuit is broke there due to not being plugged in for the original amp meter... ?If you originally had an ammeter, you have wires carrying the signal through the light underhood harness (for 1969) or the extended underdash harness (for 1970) that connect to the underdash harness, and then eventually to the dash cluster. What has been done with those wires? They are directly tied to the alternator/battery line.And also, something a bit different on my car, I grounded the engine block straight to the NEG battery terminal in lieu of to chassis. And I also have a chassis ground - from the fender apron to the NEG terminal of the battery also. Could this be causing any issue...? I don't see how, but thought I would mention it.With all the bondo you have on the car, I'm hesitant to say this is OK. Just Kidding!If you have time, and it's easier to call, I'll message you my #. If you want to that is. I'll call after my lunch is over.
If you originally had an ammeter, you have wires carrying the signal through the light underhood harness (for 1969) or the gauge harness (for 1970) that connect to the underdash harness, and then eventually to the dash cluster. What has been done with those wires? They are directly tied to the alternator/battery line.
The printed circuit board plug is just unplugged and left behind the dash, I did cut loose a few of the wires and reused them to feed dash lights, gas guage etc
Ahh, the mind of our Gov't employees...
Return that POS and get a one wire alt.
Did both things and still no luck.I'm getting beyond frustrated. This F'ing thing should work. It works when I full field jumper the VR (A+F) plug. I think it's these new damn electronic regulators.
That makes trouble-shooting more problematic, as you need to blip the RPM's to energize the alternator. And if blipping doesn't work, then what?Tonite, I'll examine the '70 charging system wiring, to see if there's something unusual in the design...
