Author Topic: Striped the 11  (Read 1102 times)
Offline monkeystash
Striped the 11
« Reply #50 on: February, 12, 2012, 07:46:15 PM »
At the bottom of the sticker almost center is a bunch of codes ending with 8 17 10.
That must be the production date.
Same day mine was made.
-Ryan
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
Re: Striped the 11
« Reply #51 on: February, 12, 2012, 07:47:29 PM »
Try this link inserting your VIN after the = ... http://fordlabels.webview.biz/webviewhybrid/windowsticker.aspx?vin=
That is not the build date....it is on the door post sticker or in the blend number on the upper left corner of the window sticker if it has a blend number on it.
Door post says 8/10. sticker says 7090 blend
Offline Sluggo
    • www.StangFix.com
Re: Striped the 11
« Reply #52 on: February, 12, 2012, 07:51:10 PM »
Interesting. 145284 here.
Offline AzPete
  • Classic...less
Re: Striped the 11
« Reply #53 on: February, 12, 2012, 07:53:11 PM »
Last six of the blend number.....year, month, day...this car May 29, 08.
http://fordlabels.webview.biz/webviewhybrid/windowsticker.aspx?vin=1ZVHT85H995101901
120080529 is the blend number.
Door sticker is usually within a day or so....blend number should be more exact.
« Last Edit: February, 12, 2012, 07:56:29 PM by AzPete »
USAF/Ret.
7 Previously owned..66-07
Offline monkeystash
Re: Striped the 11
« Reply #54 on: February, 12, 2012, 08:00:28 PM »
144168 here.
Here's my window sticker.  Look at the top left, see the 120100817?  That's the build date, 8/17.  Those numbers don't show up on the hard copy of the window sticker.  I think yours might actually have been built later in the month.
http://fordlabels.webview.biz/webviewhybrid/windowsticker.aspx?vin=1zvbp8cf2b5144168
Offline AzPete
  • Classic...less
Re: Striped the 11
« Reply #55 on: February, 12, 2012, 08:06:39 PM »
They don't show up at all on my sticker on line. The date at the bottom is close to some build dates and way off on other build dates. The bottom info on mine is 10 18 10 and build date is June 25, 10 according to my GT/CS SVT info provided by Ford. The car door sticker say the day before that. From what I read, the door sticker is the closest....unless there is different tracking because the car is dealt with thru SVT.
« Last Edit: February, 12, 2012, 08:18:22 PM by AzPete »
Offline Sluggo
    • www.StangFix.com
Re: Striped the 11
« Reply #56 on: February, 12, 2012, 08:34:42 PM »
Here's mine.
8 17 10 is under the vin and barcode at bottom center.
Offline monkeystash
Re: Striped the 11
« Reply #57 on: February, 12, 2012, 08:45:11 PM »
Here's mine.
Yours was built 8/24.  Look just left of the blend number at the top.  I believe the 08 17 10 is the date the window sticker went live.  If you look at mine it says 08 03 10.
Also, at the very bottom right you'll see the numbers again 1201008247090 which decoded is build date 2010 08 24 blend number 7090.
Offline AzPete
  • Classic...less
Re: Striped the 11
« Reply #58 on: February, 13, 2012, 05:43:28 AM »
As you see on mine....there is no blend....guess mine was an extra...lol
http://fordlabels.webview.biz/webviewhybrid/windowsticker.aspx?vin=1ZVBP8CF6B5137692
Offline monkeystash
Striped the 11
« Reply #59 on: February, 13, 2012, 11:34:16 AM »
Weird!  And, like you said, your date by the bar code is well past your build date.  It's usually 1-2 weeks before.  Hmmm, interesting.
Offline AzPete
  • Classic...less
Re: Striped the 11
« Reply #60 on: February, 13, 2012, 11:49:17 AM »
Offline sgtjunior
  • Yak, Yak, Yak
Re: Striped the 11
« Reply #61 on: February, 13, 2012, 01:58:13 PM »
Nailed it, the car looks great!
Offline monkeystash
Striped the 11
« Reply #62 on: February, 13, 2012, 05:49:17 PM »
Finally tracked down the page I was looking for....
Good find Pete!
Offline LastDeadLast
  • Active Poster
Re: Striped the 11
« Reply #63 on: February, 14, 2012, 07:04:27 PM »
I really like the stripes...
+1
-Shannon
65 Mustang vert.
331 Fuelie!!
