Author Topic: Mixing paint  (Read 334 times)
Offline BigHoss
  • Quiet Type
Mixing paint
« on: January, 28, 2012, 02:22:49 AM »
When I paint with a gun I usually wing it on the mixture. But I really wanna make this next project perfect. For example 7 parts clear and 1 part black base. Does that mean for example; for the sake of argument the paint canister holds 10oz of paint. Would you go 7oz of clear and 1oz of black base?
Offline Horseplay
Re: Mixing paint
« Reply #1 on: January, 28, 2012, 05:08:06 AM »
Get some good measured paint cups to make sure you get it right.
To answer your question, if the mixture calls for 8 parts at that ratio then yes, 7 and 1 equal eight. Using the cups makes it pretty simple and foolproof.
« Last Edit: January, 28, 2012, 05:12:27 AM by Horseplay »
Offline 67 evil eleanor
  • Forums #1 Idiot, Redneck, worst speller and u can
  • Member #12
Re: Mixing paint
« Reply #2 on: January, 31, 2012, 12:39:30 PM »
They make a stainless that has the ratios on it. It is very ease to use and clean. If the paint is not mixed with the correct amounts it can cause a failure due to the chemical agents not having the correct ratio to catalyze or react like they were designed. Here's a photo of what I use and you don't need a cup if using like a Binks 7 or other siphen feed gun. If using a HVLP then you will need to mix in another cup. It's always handy if theres another person that can mix so things can keep moving and will allow the correct flash time.
http://www.pc.dupont.com/dpc/en/US/html/visitor/b/nsn/s/library/items/NSN_3-NA331_MixStick.html
Q: What do you call a basement full of Liberals?   A: A wine cellar.
Our Congress still sucks.
Offline gwstang
Re: Mixing paint
« Reply #3 on: March, 20, 2012, 04:36:53 PM »
Cool, I just bookmarked that for the next project!   :thu
Timid men prefer the calm of despotism to the tempestuous sea of liberty. Thomas Jefferson
