Author Topic: Severe stumbling-grrr-next step???  (Read 1346 times)
Offline blue65coupe
  • Banned
  • where's my short bus
« on: May, 07, 2009, 04:15:29 PM »
Took the car out for a test drive after the e-fan install.  After about 10 minutes of driving the car developed a "stumble" at around 2800rpm.  Cleared up and kept driving.  Then, it got BAD.  Even shut off at idle.  I'm figuring it's in the "ignition" somewhere and will pull plugs, check wires, possible pertronix issue, gonna look at fuel filter, etc.  Anything I may be missing or should look at first?  Got the car back home and it had cleared up.  E-fan works though :crazy
Oil around threads on 5 plugs.  All ds and 1 ps.  Only 1 plug has a hint of burnt oil and it is the one with the most oil around the threads.  Safe to assume it's a vc gasket issue and not a ring issue? Try and just tighten or go ahead and replace vc gaskets?  Won't fix the miss but later updates for that.
____
6/1/09--new plugs and wires and finally got a break in the rain to drive.  Same thing.  Starts off good, pulls good through the first "gunning", then it misses like crazy under a load.  I can let off the gas, get back into idle and it will smooth itself out.  Put it under a load and we want to go nowhere.  I haven't changed Pertronix, coil, solenoid.  New fluids with no oil/water, water/oil.  Next thing to check would be.....
« Last Edit: June, 01, 2009, 11:29:00 AM by blue65coupe »
Duane
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
Re: Severe stumbling
« Reply #1 on: May, 07, 2009, 06:39:35 PM »
did you put a relay on the fan circuit?
Offline blue65coupe
  • Banned
Re: Severe stumbling-update 1
« Reply #2 on: May, 07, 2009, 06:51:36 PM »
what?  No, direct wired to the battery.  It's an adjustable temp controlled (built in relay).  The stumbling (miss) took place the other day when it ran a little hot...before the e-fan.
« Last Edit: May, 07, 2009, 07:03:55 PM by blue65coupe »
Offline AzPete
  • Classic...less
« Reply #3 on: May, 07, 2009, 06:55:49 PM »
If the valve covers are light weight tin, put on new gaskets and be sure surface of valve cover is flat around bolt holes.
If they are the heavier aluminum ones, try tightening them down but do not over torque.
USAF/Ret.
7 Previously owned..66-07
Offline blue65coupe
  • Banned
Re: Severe stumbling-grrr-next step???
« Reply #4 on: June, 01, 2009, 11:31:14 AM »
bump for update
Offline AzPete
  • Classic...less
« Reply #5 on: June, 01, 2009, 11:36:13 AM »
Coil or electronic ign. controller getting hot? Could have gotten damaged from the overheat, now it is more sensitive. Had that on my Dad's '82 Ford Country Sedan with a 302. Poured water on it when it acted up, all ran good until it got warm again. Replaced and no more problems.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #6 on: June, 01, 2009, 11:42:38 AM »
could be cracked cap or bad plug wire too. Under load, the volts take path of least resistance. If you can pull it in the garage or somewhere dark, open hood and brake torque with someone standing to the side and see if you have a light show of sparks somewhere...
Offline monkeystash
« Reply #7 on: June, 01, 2009, 11:48:00 AM »
Maybe you are boiling fuel in the bowls.  Is the carb hot to the touch when this is occurring?  If so, make a 1/8" thick wood spacer with a jig saw and your carb will never again be hot again.
-Ryan
Offline blue65coupe
  • Banned
« Reply #8 on: June, 01, 2009, 12:05:38 PM »
I've got a spacer under the carb.  I'm gonna check the coil, ign, and cap.  I doubt it's a wire per se since they are new and it's doing the same thing.  I'm gonna try the brake torque trick but doubt I'll be able to pull much.  It likes to spin.  Ahhh, what to buy first.  I'm guessing replace the pertronix.  Thanks guys
Offline silverblueBP
    • My 66 2+2
« Reply #9 on: June, 01, 2009, 12:48:00 PM »
A different fork in the road; what about a fuel issue? Possibly something in the carb jets blocking the fuel. I've had it happen to me and damn near pulled my hair out going through the electrical side of things. Ended up being a pc of rubber blocking one front jet just enough that when it got into the higher rpm's it started stumbling. I thought it was electrical too until a friend asked if I had checked the Holley jets.
-Mark-
CarDomain
Offline blue65coupe
  • Banned
« Reply #10 on: June, 01, 2009, 01:22:17 PM »
I'll pop the cleaner and filter off tonight.  Check it out and go from there.  Thanks.
Offline blue65coupe
  • Banned
« Reply #11 on: June, 02, 2009, 11:27:32 AM »
Replaced cap, ff, coil.  No luck.  Carb looks good however, old ff was FULL of stuff.  I'm gonna check the new one since it's been on for one drive and see how it looks.  If bad, drain tank.  If good, pull a compression test just to be sure before I start spending any more money.  I doubt that's it but WTH!!!  I can stay in the gas and it will bog down like crazy, get a little full power spurt and then back down.  HEY PAT, WANNA BUY A COUPE?
Offline AzPete
  • Classic...less
« Reply #12 on: June, 02, 2009, 11:40:23 AM »
So have you replaced the pertronix? You might try a set of points just for the heck of it....
Offline blue65coupe
  • Banned
« Reply #13 on: June, 02, 2009, 12:47:04 PM »
Not yet.  Was not wanting to get to that due to the money and it probably not working.  Cheap stuff first you know.  While we were doing the rebuild, the guy helping me installed the pertronix.  (That was 3 years ago in case you're wondering)  That means, I've never done it so I don't know what's going to be involved going back to points.  I figure something was removed.  Mark mentioned he's running a 6al and thought about that if I have to go that route.  I just have to get the pertronix out and see if that's the problem.  PIA, PIA, PIA
Offline AzPete
  • Classic...less
« Reply #14 on: June, 02, 2009, 12:54:13 PM »
Going to points is not hard. Not much to fix with the pertronix, replace or not. Check the wires coming out of the dist. to the coil. Make sure they have not worn anywhere and causing an intermittent ground. There is also a small pickup that slips over the dist. cam. Make sure it fits snug.
Offline blue65coupe
  • Banned
« Reply #15 on: June, 02, 2009, 12:59:41 PM »
Everything with the pertronix looks good.  Now, before I replace it, what's involved in going back to points?  I will do that before I purchase anything to see if it works.
Offline AzPete
  • Classic...less
« Reply #16 on: June, 02, 2009, 01:16:54 PM »
On a standard distributor, you will need the points and condenser. There are three short screws used to hold them in place. Two are for the points, one is loosened for adjustment, the other is used to lock them down. The third is used for the condenser. You will most likely need to buy these, which would look like the one that is used to hold down the pertronix. Length is critical. Looking at the plate with the pertronix removed, it should be easy to see the layout. Once installed and wired, adjust. Forgot about the one screw for the ground wire too. There is a screw where the screwdriver is at.
I will see if I can find a picture which will help you know how things go.
« Last Edit: June, 02, 2009, 01:21:39 PM by AzPete »
Offline blue65coupe
  • Banned
« Reply #17 on: June, 02, 2009, 01:25:01 PM »
thanks
    • My 66 2+2
« Reply #18 on: June, 05, 2009, 12:55:46 PM »
Any update on your POS Duane??
Offline blue65coupe
  • Banned
« Reply #19 on: June, 05, 2009, 04:29:46 PM »
Nope.  Still a POS.  Pertronix should either work or not.  No in between so it looks like I don't have to go into that part.  I'm going after the entire fuel system this weekend.  Tank, lines, everything.  We'll see what happens.  Anyway, I got a spare set of plugs, wires, cap, button, coil, etc laying around.
Offline blue65coupe
  • Banned
« Reply #20 on: June, 07, 2009, 04:10:19 PM »
A decent amount of sediment in the fuel after draining.  Blew out lines and some crap in it.  Carb still looks good but haven't taken it off.  I've got a question though.  Considering I have some stuff mounted in the trunk area that requires disconnecting/disassembly/removal in order to get my tank out, I was wondering if anyone had ever flushed a gas tank without removing it?  I have a drain plug in the tank so lifting the lr will get all liquid out.  If I remove it, I'm just gonna buy a new one.  Anyone ever done this...with luck?
Offline AzPete
  • Classic...less
« Reply #21 on: June, 07, 2009, 04:19:16 PM »
For the cost vs hassle of cleaning, I would just get a new tank. To clean it, it should be removed. You can flush it but that just gets most of the loose stuff until you hit another bump and knock more crud of.
Offline blue65coupe
  • Banned
« Reply #22 on: June, 07, 2009, 04:28:14 PM »
Decision made.  New tank.  Just pulled the sending unit and decision was made.  Time to start unhooking crap.  Thanks.
Offline blue65coupe
  • Banned
« Reply #23 on: June, 14, 2009, 04:09:30 PM »
Not the tank.  Ran good for a little, then nada.  It actually cut off on me this time and took about ten minutes to get started again.  Acts like no fuel but will take it all of a sudden.  Won't get to mess with it this week but hopefully this weekend I can start from the pump and go up to the carb.  I REALLY didn't want to take the carb off but looks like I'll be following Mark's and Dave's orders.
    • My 66 2+2
« Reply #24 on: July, 06, 2009, 07:25:33 AM »
You fix this yet??
