Linux Mint 11 Rulez....
We do it two ways, base coat /clear coat. Or we spray on U-Tech etch primer, then spray our Vortech bed liner material. No the bed liner material doesn't add a lot of weight.
You shouldn't need more than a quart of Pors-15 if you are going to brush it on. That stuff goes a long way but if you have any left over it doesn't have a long shelf life. When you brush it on it levels out pretty good also.
The thing with the bed liners that always concerned me was their texture. I would think that would lend itself to the collection of road grime, etc. What I find appealing about using one would be the sound deadening I assume one would gain.Thoughts?
thanks, never used it before, been reading up on it, seems like it's pretty thin and goes a long way. I thought I might need 2 quarts but looks like 1 will be plenty. I wish I had some way to get it all down in the cowl area, I got some comparable rattlecan stuff from Eastwood for that with a long flexible extension, I am hoping I can get good coverage down in there also (not to change the subject but since we're talking about POR15).
I would ask Justin "gtscode", his method to coating the cowel is genius.
I used Zero Rust for the extra protection factor ( the red oxide was kind of similar to the original color on this San Jose car).
I poke 4 holes in the tops of all my paint cans, this way it drains back in the can. Then I take a paper towel and wipe the rim completely clean. If you don't clean the rim you WILL destroy the lid and the can trying to get it off. Now if your just using any primer or some miracle epoxy primer the lid will come right off.
+1 I used all black Zero Rust... brushed on.
If you don't properly prep any surface regardless of what you want to top coat with you will have problems. SPI or any other epoxy or direct to metal primers will peel also if you are trying to put it over a slick finish. When I use the KBS I never put it over rust, my metal is new and have been using it for the last 16 years.
