I did before doing what I did. 4V seems to be the common one. But I might want to keep looking. Maybe cap off the inlet and see if it makes a difference I'm thinking.
Is that a 2V spacer?
I have an OEM 1" Spacer with a PCV port, it also has an EGR Valve. It's in great condition, I would sell it for $20.00 plus shipping.
You should be able to plug it pretty easy.....or maybe not after checking on line pics.......hmmmm.
I've never seen one with a EGR valve...do you have a picture ??
That is kinda what's confusing me. When I bolted on this one it fired right up and ran but now it won't. I did run the pcv hose to a inlet on the intake that was capped off. (the other used to go into the base of the old carb but this one has no input). I'm wondering if that screwed things up. That is the only thing different that I can think of.
That....and a new tune to be sure all is as it should be.
Thank's for the offer jmbour66, but I think this one will fit my application better. I bought this spacer off E-bay. I think it will do the trick.http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390264843370
Well, what happened? Did it work?
