Sure you got the correct lug nuts? I thought those wheels took the type with a shank about an inch long or so. This also centers the wheel.Sometimes you can file down some excess metal on the caliper depending on where it touches.
How in the heck do you shave off excess metal off a caliper?
I think your GT wheels looked the best so far.
Get the right wheel that has clearance for the calipers.
Lug nuts barely fit on the studs and the wheel barely fits over the caliper. You can hear the caliper scrape a little if you slowly turn the wheel.Could I change calipers to something smaller? Might be kind of hard though finding one that will work with the kit/bracket I have.
I swear when i had these on my first car the had an oval shaped chrome piece that went in the lug hole.
Those were the universal fit type and most also took a nut with a shaft..........
Yes or No?
Kinda like Kat...
No!
