Author Topic: My adventure/process in homemade adjustable Strut Rods (pics).  (Read 1867 times)
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
Re: My adventure/process in homemade adjustable Strut Rods (pics).
« Reply #25 on: December, 28, 2011, 11:04:48 AM »
J. your fab work is awesome as usual.  I can't help but wonder though, wouldn't it be much easier to bend a piece of steel, something similar to what jonk posted?
Where did you get your heim joints from?  I've been looking for some.
From Speedway:
http://www.speedwaymotors.com/Chrome-Plated-Moly-Body-Rod-Ends-Heim-Joints-LH,7063.html
And yes, it would have been hella easier to bend and.or weld up some end brackets.  But I like this better.
Offline silverblueBP
    • My 66 2+2
« Reply #26 on: December, 28, 2011, 02:27:15 PM »
Been cheaper to just buy them from Shaun, but since you're a tightwad......
-Mark-
CarDomain
Offline 70_Fastback
« Reply #27 on: December, 28, 2011, 02:50:08 PM »
Huh...?  :shrug
Quote
Details
Part Number:  ST-STSR
Price: $369.00
    • My 66 2+2
« Reply #28 on: December, 28, 2011, 03:01:29 PM »
If labor is free in your world, you can build me a rat rod!
Offline Jonk67
  • Yak, Yak, Yak
  • Smyrna, TN
« Reply #29 on: December, 28, 2011, 04:14:20 PM »
I guess mine looks like a bent piece of metal but it's a rod clevis from CRC. I found it in Daze's instructions I used as a guide to build my own but I used the 3/4" RC-07 for my '67 vs. Daze's RC-05 7/16" for his '64 1/2.
http://dazed.home.bresnan.net/adjustable
 http://www.crconline.com/Components/Component_Parts/threaded_rod_clevis.html
I got my rod ends/swedge tubes from speedway also and bolts from Fastenal.
Jon
Offline 70_Fastback
« Reply #30 on: December, 28, 2011, 07:16:43 PM »
Sure thang buddy.  I will warn you though.... my material markup is rather substantial...
Offline lethal289
  • Steel Hoods Rule!
« Reply #31 on: February, 10, 2012, 07:12:23 PM »
Mind sharing where you found the tube coupling?  It doesn't look like the standard swedged one everyone else uses!
Offline 70_Fastback
« Reply #32 on: February, 11, 2012, 07:24:03 AM »
You mean the heims joints?
If so, I ordered them from speedway.  I thought I posted a link to the heims earlier in the post.
Offline 70_Fastback
« Reply #33 on: February, 11, 2012, 07:26:49 AM »
From Speedway:
Here Jake.
Offline lethal289
  • Steel Hoods Rule!
« Reply #34 on: February, 11, 2012, 09:58:44 AM »
Sorry, maybe it is a swedged tube.  Its just not the standard gold?  I mean this one.
Online SELLERSRODSHOP
  • Nick Jr.
  • I smell smoke....
« Reply #35 on: February, 11, 2012, 12:00:00 PM »
i think he said he made those with leftover DOM tubing from the ratrod build.
Offline 70_Fastback
« Reply #36 on: February, 11, 2012, 12:13:38 PM »
Ah, I see.  And yes, Steve is correct.  I had to enlarge the O.D. just a bit and then tap the fine threads.
Offline 70_Fastback
« Reply #37 on: February, 11, 2012, 12:15:31 PM »
And I did get them powder coated and installed.  They fit fine - except i had to change from a standard nut to a jamb nut.
Now I need an alignment.  Big time.
I will post some pics of the finished pieces and the inner bushings that I made.
    • My 66 2+2
« Reply #38 on: February, 11, 2012, 03:30:06 PM »
Sounds like an alignment party at Bob's!
Offline 70_Fastback
« Reply #39 on: February, 22, 2012, 02:48:24 PM »
When?  Needs to happen in less than 4 months.
Offline 70_Fastback
« Reply #40 on: February, 22, 2012, 03:02:08 PM »
And I am finally getting around to uploading the rest of the pics of the bushing spacer and the powder finish.  Sorry it took so long.
I made these bushings to take of the slack of the old rubber bushings in the strut rod mounting holes:
It's actually 3/8/ steel cut out with an 1-5/8" hole saw.  The I.D. of the hole saw was the exact fit.  Center drilled out to a tight 5/8".
The spacer fits the hole perfectly:
Stut rod temporarily installed.  It fit - but the regular nut was touching just a tad, so I changed to a jamb nut for final assembly:
And as far as the nut retaining side, I wasn't comfortable with just the 5/8" washer over that enlarged hole - it just wasn't big enough in my opinion so I cut out my own heavy duty, enlarged washers.  Note the middle is the standard 5/8" washer in comparison to my cut spacer on top - not much size difference.  My fab'd one on the bottom.  Much larger:
And here they are powder coated and finished:
Now to do some undercarriage cleaning and repainting....  :hide
    • My 66 2+2
« Reply #41 on: February, 22, 2012, 04:48:35 PM »
It's your frick'n car, just tell us when.
Offline 70_Fastback
« Reply #42 on: February, 22, 2012, 05:06:04 PM »
My place?
    • My 66 2+2
« Reply #43 on: February, 22, 2012, 05:37:33 PM »
My place?
All you have to do is put the word out. I think Bob has all the stuff to align, but if not, I can bring my C/C gauge and toe checker thingamabob.
Offline Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #44 on: February, 22, 2012, 05:42:56 PM »
Wow!  That almost looks like Jeremy's work.
Panama City, FL
Offline lethal289
  • Steel Hoods Rule!
« Reply #45 on: February, 22, 2012, 06:33:48 PM »
Whats the extra hole for?
Offline 70_Fastback
« Reply #46 on: February, 22, 2012, 06:40:14 PM »
It's a lightening hole....
I am here:
    • My 66 2+2
« Reply #47 on: February, 22, 2012, 06:48:35 PM »
That's where he forgot to measure TWICE.
Offline 70_Fastback
« Reply #48 on: February, 25, 2012, 04:06:26 PM »
Winna winna chicken Dinah!  That's where I had the chunk the wrong direction in the drill press. I meant to weld it up but forgot. Now I just say "that's the left one".
Offline 67 evil eleanor
  • Forums #1 Idiot, Redneck, worst speller and u can
  • Member #12
« Reply #49 on: February, 27, 2012, 01:33:18 PM »
Nice work......
Q: What do you call a basement full of Liberals?   A: A wine cellar.
Our Congress still sucks.
