My instructions I gave you in writing with the harness work well with this. Here's what you do:
Connect everything up except the battery. Connect the positive battery cable to the starter solenoid. Now use a volt-ohm meter set to DC current, and measure the current between the disconnected negative battery cable and the negative post on the battery. With everything turned off on the car (don't forget headlamps, cigarette lighter, door lights, etc.), you should see a current draw of 100 milliamps or less. Anything greater than that (like 1 or more amps) indicates a short somewhere. If you have high current draw, first remove fuses one by one, and retest the current draw. You'll likely see a great drop in current; if so, the fuse that lowered the current indicates the circuit that has the draw. If the draw is still high after all fuses are pulled, start by removing the voltage regulator plug and re-test the current draw. If still high, start removing wires from the starter solenoid one by one, retesting after every removal. Eventually, you'll see the current drop. The wire that you removed that lowers the current draw is the offending wire.
After you fixed everything, re-test your current draw. Only connect the battery if your current draw is 100 milliamps or less.
