I thought you just exploded the engine to stop.....
FWIW, I have a dual MC, 1" bore with discs up front and drums out back. Works fine without too much effort or pedal travel.
You're not I'm sure. But, flex hoses all have some give. The more you add in, the less firm the pedal will feel as the hoses expand. I would work on another way to clean them up.
Squeeze your front brake lever hard and watch for line flex/movement. My Wings that had the same lines always had a bit of flex but the bike itself never needed so much application that it was an issue.Leg pressure vs hand squeezed application also makes a difference.
