Is there really two buss bars that a dual pole breaker contacts? I thought it was a single buss bar that a breaker snaps into and that a dual pole breaker is essentially two 110v breakers combined, providing two hot leads to the outlet. I know a normal breaker box has two vertical rows of breakers (two buss bars), but a breaker only contacts one buss I thought. I'm not electrician though
A home 220vac outlet should have three wires. Two hots and a ground. This is called single phase. Three phase 220 has four wires, three hot and a ground. This is an "industrial" set-up that you will not find in a residential set-up.
