Sure would be nice to have some windows behind a work bench like that.
for this T5 World Class W/bell/new clutch/flywheel/clutch fork- I tore it down today and was amazed, It's like new
Is it a rule that everything takes two or three times longer than you thought it would?
Raining here, but a few teaser peektures that I squeezed off in the dark garage... Good ones to come as soon as all the winter projects are completed. You can see glimpses of the orange Konis and tires too... I've spent under $1000 total, including the brakes, shocks, struts, tires & headlight set...
The 3-day weekend's over and I'll have to wait till Saturday to make use of my new engine hoist and the carb plate I borrowed from craigmayna. Is it a rule that everything takes two or three times longer than you thought it would? I did however bolt an intake onto the broken engine and torqued the carb plate to that.
Must be a transmission week? I have been so busy i got a little time this weekend to LOOK at my car for an hour, But saturday some kid called on my craigslist add for my C4 We swapped trannys, I got the better deal I traded my C4 no bell/no tc/ and a B&M ratchet for this T5 World Class W/bell/new clutch/flywheel/clutch fork- I tore it down today and was amazed, It's like new ]
The tranny will shit fine till the input shaft is spinning and trying to mesh the output shaft :)
How much is that hydraulic TO bearing setup?
Did you just open it up or completely strip the clusters? The tranny will shit fine - Also don't use RTV on the reassemble. .
You owe me a monitor!
