Ouch. You try to be nice to a guy and this is what you get. Your day is coming mister. Just wait. With Parnelli Jones as my witness, I will pass you by with such vengeance that your underbritches will be full of shart.
Not a bad ground. Not bad relay. All that stuff was checked, which is why the guys working on my 03 are confused why they won't work.
Positive (+) wire to one side of light bulb, Negative (-) to other side of light bulb. Positive (+) attached to 12 volt source, Negative (-) attached to ground............light bulb lights. If no lighting happens, either (+) or (-) is missing from the bar fight
You might be able to switch the fog relay with another on the car to see if it helps.
http://www.moddedmustangs.com/forums/audio-video/84165-how-keep-fog-lights-high-beams.htmlTell them to read that, should help the troubleshooting as you can bypass the fog light kill switch (with high beams on). The cut out drops the ground to the fog lights. If your relay stuck shut, the ground will be interrupted and not allow the fogs to work.
Cars have heaters
Only if they leave the garage!
I can probably find you a 65/66 blower motor from a local Mustang salvage yard if you need one.
Installed the wiper on the 66 (that was a pain in the butt) & cleaned the inside of my '03 GT Oh and the guy who borrowed my GT wheels, brought over 2 of his wheels he had on his 68. Front and rear. Both 17s. Gonna see how they fit/look on Gertrude later tonight.
